Old 11-13-2008, 01:55 PM   #16
jammin big bores are 16mm shocks and im sure they fit , have them on mine ebay is probrally the cheapest i once found them for like 80 dollars for the hole set with stand offs
Garrison is offline   Reply With Quote
Old 11-14-2008, 02:07 AM   #17
Default xt8
cheers guys. what do u think of 4500 silicon oil in them big bores??
muaythai is offline   Reply With Quote
Old 11-29-2008, 07:14 AM   #18
lethalleigh29's Avatar
Jammin/Hong nor big bores fit this truck perfectly.
lethalleigh29 is offline   Reply With Quote
Old 12-01-2008, 04:33 PM   #19
c baron's Avatar
I'm running the stock shocks with the 4 hole 1.3 pistons I drilled 2 holes in the pistons and I'm running losi 55wt oil with dark blue springs. on a bumpy bluegrove track the truck was dialed.
USED TO BE HURRICANE RC TRACK DIRECTOR
-RC AMERICA-
-XRAY-
-ELITE PERFORMANCE-
-JCONCEPTS-
c baron is offline   Reply With Quote
Old 12-01-2008, 05:07 PM   #20
Trader Rating: 54 (100%+)
I am running the same setup as powerhouse, 808 rear shocks all the way around with the losi arm standoffs for the lower mounting position.
jsmax is offline   Reply With Quote
Old 12-02-2008, 12:07 AM   #21
Default xt8 big bore
right guys finally got to test my xt8 with caster big bore on a bumpy trek where i live.
used blue springs all around. 40wt rear and 40wt plus top up 50wt ( which probably makes it abut 45wt).
I am not a pro and usually will have to pick my car up 3-4 x in an hour or practice.
my god , the drive was amazing. completed so many laps with no running to the track.
really had a good time and feel real lucky got my truggy to run so well.
pm me if u need more info
Old 01-02-2009, 09:54 PM   #22
asw7576's Avatar
Are these really bigger than XT8 shocks ? What is 16mm ?
http://www.amainhobbies.com/product_...ducts_id/16927
Old 01-02-2009, 10:05 PM   #23
wild gopher's Avatar
Trader Rating: 39 (100%+)
they are bigger than the stock XT8 shocks. The 16mm is the width of the body. Stock Xray is like 13mm or somewhere in that area. I would recommend the 808 shocks over the Jammin
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 01-03-2009, 12:35 AM   #24
kanai kid's Avatar
Send a message via AIM to kanai kid
wanting to try the 808 big bores on the truck. can someone give me the part number of the losi part that i need to get the full droop?
kanai kid is offline   Reply With Quote
Old 01-03-2009, 12:44 AM   #25
hi mate, i really suggest the caster big bores. cheap but amazing !
Old 01-03-2009, 02:47 AM   #26
KANAIKID, you need this part LOSA1723, think amainhobbies have them, unfortunatly you have to buy the whole set with rear arms (you dont need losi arms)
also you can use team associated big bores rc8t.they perfectly fit ASC89338,ASC89346,ASC89083,ASC89082
hope this helps
ANDRAZ is offline   Reply With Quote
Old 01-03-2009, 08:14 AM   #27
kanai kid's Avatar
Thank-you for the part number. Really stinks that I have to buy them like that.
Coffee Shop for 1/8 RC Offroad mikeychenchiulu Indonesia Racing 10180 11-29-2013 03:39 PM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
