Old 11-06-2008, 01:27 PM   #1
Default OS .21 vz-b v-spec, what pipe?
Hey guy's, I've been looking all over the net for pipe recommendations for this engine. I have found a few varying opinions. I was set on the sirio cl3b but i thought I'd stretch and buy the os!
Initially i was set on an os 2060 pipe but this seems very expensive and possibly not worth the extra cash. I have seen many recommend the jammin pipes, the jp-1 doesn't sound like a good choice as it's mainly for tight tracks but it seems like the jp-2 and jp-3 might be what i'm after.
The track i race at has about 3 decent length straights that you can really open up on. Lap times are about 38-39's for the quick guy's.
Any advice appreciated.
-Hugh
hugh_b is offline   Reply With Quote
Old 11-06-2008, 01:31 PM   #2
Trader Rating: 27 (100%+)
I personally really like the AE/TT 2035 pipe and run it on my OS Speed as well as on my V-Spec. JP3 ain't too bad either and people say that it gives a little better fuel mileage.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 11-06-2008, 01:39 PM   #3
Marcus Falconie's Avatar
Default jammin
The Jammin pipes are what most of us run at my track on the V-Spec. It's easy, you want bottom you run the jp 1 you want mid ant top you run the jp 3. I run the jp 3 with my V-Spec with great results. This is a video of CW at the nitroX at the Nitro Pit with the jp 3 V-spec.
www.youtube.com/watch?v=2nrKjKZcmHY
Marcus Falconie is offline   Reply With Quote
Old 11-06-2008, 01:46 PM   #4
Thanks guy's, sounds like the jp3 is the pipe to go for then!
Old 11-06-2008, 02:13 PM   #5
stump27's Avatar
the last time i ran my x2 crt i got nearly 12 minutes on a vspec with jp-3.....
stump27 is offline   Reply With Quote
Old 11-06-2008, 02:19 PM   #6
that's what i like to hear! The youtube video is great! Looks like an awesome set-up
Old 11-06-2008, 02:32 PM   #7
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i would say either 2013 or jp3
jamminnay is offline   Reply With Quote
Old 11-06-2008, 03:05 PM   #8
Maximo's Avatar
JP4 and MSR 1005 work well as well...the MSR is very good actually !
Maximo is offline   Reply With Quote
Old 11-06-2008, 03:12 PM   #9
Reevo's Avatar
My VZB loved the Dynamite Platinum pipe...053MR...Also the OS 2060 is great but pricey.
I got some RC stuff.
Reevo is offline   Reply With Quote
Old 11-06-2008, 03:36 PM   #10
os 2050 is the only way to go. OS pipes last 10 times as long as a JP-3.
Asti is offline   Reply With Quote
Old 11-06-2008, 06:12 PM   #11
jpz_67's Avatar
Trader Rating: 56 (100%+)
Os 2050.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 11-06-2008, 06:15 PM   #12
DriftProjectR's Avatar
Trader Rating: 38 (100%+)
on my V-Spec i run the OS 2060 pipe. i personally like it and i get around 12 min run times.
Hot Bodies IFMAR Worlds
OS Engines
Ace Servo
BCE Design
Bodies By Scott
Lungsford Titantium
M2C Racing
DriftProjectR is offline   Reply With Quote
Old 11-06-2008, 06:43 PM   #13
hambone's Avatar
2050 is a brute on the v spec. 2060 pretty sweet too on big tracks or tracks that lack grip.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 11-06-2008, 09:03 PM   #14
stump27's Avatar
what do you mean by that? i personally find it easier to clean and maintain a hardcoated pipe than a polished one. only recently did os fix the problem with the pressure nipple coming off. my jp3 is over 2 yrs old and works perfectly. curious as to what you meant?? thanks
Old 11-07-2008, 08:58 AM   #15
The original 2050 was clear coated and was very easy to clean. In 2006, OS re-released the Mark Pavidis 2050 and it was not clear coated, but if you use an SOS pad, you could clean it right up. What I meant about lasting longer than the JP pipes it that the wall thickness of the 2050 is double that of the JP-3. The JP pipes smack down on the mud guard and the belly of the pipe flattens out. You really have to try to dent a 2050. I have some 2050s that are 4 yrs. old!
