Old 11-06-2008, 08:11 AM   #1
Default Fioroni Clutch on Xray 808?
Does anyone know if you can use the Fioroni "2007 Turbo Twin" sliding clutch system on the Xray 808?
Thanks!
Larks is offline   Reply With Quote
Old 11-06-2008, 09:14 AM   #2
Reevo's Avatar
Yea I was wondering which Fioroni would work on my XT8?? Right now I've got the stock 3 shoe setup....
I got some RC stuff.
Reevo is offline   Reply With Quote
Old 11-06-2008, 09:20 AM   #3
kyosho 33 mm flywheel is the one that fits the rest are to large
Garrison is offline   Reply With Quote
Old 11-06-2008, 09:49 AM   #4
I have recently switched from Mugen MBX5R to Xray 808 and the Fioroni turbo twin slider I used on the mugen went straight on to the 808. I had to put a few spacer washers behind the flywheel to move it forward. The Mugen collett is a good fit to the Fioroni flywheel (just had to shorten it a little so it does not petrude in to flywheel lock nut too much).
I reckon this clutch is the best on the market, large contact area + shows very little wear after 6 months of use and very easy to remove & tune by changing springs (I use the black shoes).
old but fast is offline   Reply With Quote
Old 11-06-2008, 10:00 AM   #5
OMG, thanks so much for your input. I am so glad I can use the fioroni clutch system. I was sweating about that. I have had really bad luck w/ the 3 and 4 shoe designs. I am with you. The Fioroni system is the best out there.
I use the black shoes as well w/ c6bb. People think I'm nutz, but I would rather drive with a feather finger, and then have the snap to pass someone in a tight turn.
Old 11-06-2008, 10:10 AM   #6
Yes the car will be more drivable with a clutch that engauges smoothly, less chance of the backend breaking away. Don't use the blue shoes as they will slip.
Old 11-06-2008, 11:05 AM   #7
Trader Rating: 52 (100%+)
Yes the Turbo clutch fits just fine..however I will tell you if you run the active diff for some reason it will go through shoes pretty quick.thanks
MO
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
