Old 11-04-2008, 02:12 AM   #1
Default Really, Really bad noise
I have a really bad noise coming from my centre diff what could it be i need help quick got race in 2 dayss !! HELP!!!!!!
Blower Uper A is offline   Reply With Quote
Old 11-04-2008, 05:28 AM   #2
Trader Rating: 42 (100%+)
Low diff fluid, internal gears worn out, internal gears improperly shimmed, bad carrier bearing(s), bad clutchbell to spur mesh, spur and clutchbell worn out, bad clutchbell bearings are some of the possible problems.
What sound is it making, clunking, whinning, etc.?
Hope this helps
mracer is offline   Reply With Quote
Old 11-04-2008, 07:58 AM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
You need to take it out first of all and look for something obvious. Only thing that would be wrong with the center diff but not actually is the diff itself that could be making noise would be gear mesh with the spur and clutchbell or the diffs bearings holding it to the center mounts.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 11-04-2008, 08:07 AM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
Just to reiterate what the others have said.
First, check gear mesh and the condition of the clutchbell and spur gear.
if that's not it:
2. Check clutch bearings.
3. Pull out the diff and check the bearings it rides on.
4. Now that the diff is out, work the diff by hand to see if it feels clunky or notchy or gritty or just plain screwed. If it is take it apart and look for worn out or misaligned internals. In fact, do this even if it feels fine.
5. If you still haven't found the problem, keep looking elsewhere.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-04-2008, 11:13 AM   #5
RickBac's Avatar
Trader Rating: 20 (100%+)
as above plus
if it was an RTR then it probably had grease not diff silicon in it. When you clean it put in the appropriate weight of silicon in the diff.
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 11-04-2008, 08:27 PM   #6
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
Arrow
check the diff bearings also
jamminnay is offline   Reply With Quote
Old 11-04-2008, 09:25 PM   #7
Thanks guys.
Mracer Its a noise like it has bad grooves in gears and sounds like a growl
got any ideas?
me and my dad are about to change the gears see if it fixes them :P
cheers
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 06:15 PM
FOR THE NEWBIES!!! IF YOU ARE NEW READ THIS omaharich Electric On-Road 54 01-18-2007 01:32 PM
compressor or C02 maverick88 Painting, Designs, Graphics and Photography 7 11-28-2005 05:17 PM
Higher end radios brushless Electric On-Road 17 05-16-2005 03:47 PM
Airtronics Digital Servo Noise/Problem? Blakesrc Electric On-Road 12 10-15-2004 10:11 AM
