RX battery and charger help?
Hi, iam new to 1/8 buggy racing and I would like to know what kind of RX battery and charger I should get. I want a fast charger that want brake the bank maybe less than 50$ and a battery that will last a long time I may buy a couple of batteries. I have a Mugen 1/8 buggy. I run a JR 9000s T/B servo and Airtronics 94359 for my steering both are digital and I run a Futaba 3pm 2.4GHz system. I don’t run lipos yet because I don’t know what to get and iam kind of on a budget, I do have a few nimh batteries but they don’t last long they are 1200mah and I have a cheap wall charger with no timer that takes forever.
Here's what I use....
http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
It's cheap and has decent features...will charge at up to 3amps on AC power. The only drawback is the "speaker style" outputs. I made up a little adapter that has female banana plug connectors that I leave attached all the time.
Here, try one of these:
http://www3.towerhobbies.com/cgi-bin...&I=LXTCJ9&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXTCK0&P=SM
A buddy got the 220 (programmable one) in a swap a couple of months ago and it's been great. If you can spare the extra $10 for the 220 it's always nice to be able to set the charge rate exactly where you want it. As far as the battery, I just bought a 1600 mah Orion NiMh at the LHS for $35. They had both hump and flat packs, should be just what you need. You might also look on-line at ProMatch and see what they have for receiver packs.
any one else? and wht will i need to connect my j plug on my rx battery to the charger? can you charge more than one at a time and how long does it tak to charge a 1600mah battery? sorry iam new to all this battery stuff?
You could try this charger it close to your price range. Its simple and tough.
http://www.airlandhobbies.com/catalo...1240046105.htm
These Hyridmax RX packs arn't bad at 1400mah. You can get these is in hump packs or flat packs.
http://www.airlandhobbies.com/catalo...1280122032.htm
hope that helps.
hope that helps.
i run a 1400 nimh integey rx pack... i also use the pulsar charger. you can pick them up for really cheap on ebay or on here... you will need a power supply for that charger but those are pretty cheap also
I started with the DTX Digital Piranha charger and still have it. Its easy to setup and use and charges just about anything you can connect. I used it for rx and tx pacs, stick pacs for starting wand, rechargeable AAs and gel cell.
I've seen them used in teh FS/FT thread here for way below your budget and as long as you treat it decently, you should be able to sell down the road when you need a charger with more or diff features.
I charge my Rx packs at 1 amp, so it ould take 1.6 hours to charge a completely dead 1600 mah pack. I run two practices and two 6 minute qaulifiers using two digital servos before recharging. Topping off the battery pack normally only takes 25 minutes. I start the recharge before going out to marshal the next race.
at club races i normally top my pack off at least once during the day... big races i normally charge more often just because of the downtime....
