Old 11-02-2008, 08:33 PM   #1
TC3ElectricGuy's Avatar
Default Toe in - Tow out
Ok. well my buggy has about 3degrees toe out at the front and 3degrees tow in at the rear.
is this too much.
if i change the rear to 1degree toe in will this give me more top end speed, or will it affect handling.
also. the front toe out, i know they shouldn't be toe in, but how much tow out is too much.
thanks
Team Losi 8ight 2.0
Axe Cobra X1 Evo .21 engine
Axe 2050 pipe
TC3ElectricGuy is offline   Reply With Quote
Old 11-02-2008, 08:47 PM   #2
r1harper's Avatar
Trader Rating: 24 (100%+)
well i will give my 2 cents. the less toe in the rear yes more top speed is possible, but it will be a little more loose in the rear. on the front it is the same, more tow out and yes it does scrub top speed on the straights, also tow out is better turn in and toe in is the opposite. hope this helps.
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 11-02-2008, 10:26 PM   #3
Trader Rating: 42 (100%+)
+1
I would go to 2 degrees front and either stay at 3 or go to 2.5 in the rear. I think its affects on top speed are on down the list of things that will slow you down.
mracer is offline   Reply With Quote
Old 11-02-2008, 10:32 PM   #4
thanks guys. was just curious as another guy i race against has almost 0 deg at the back and maybe +0.5 towout at the front. the look of the cars is so staggering when placed next to each other.
but i'm happy with the cars steering and it was running awesome at the race meet yesterday. if i can't gain anything huge from squaring it up a fraction, then i'll leave it as is.
Team Losi 8ight 2.0
Axe 2050 pipe
Old 11-02-2008, 11:19 PM   #5
buckeye34's Avatar
If it handles good for your style, then leave it alone..you will gain more speed that way, other that trying to "fine tune" which may just cause you more headaches....just my .02
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 11:12 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
OCM KAOS DOMINATING zixxer Nitro Off-Road 2251 01-21-2010 07:31 PM
The Best Truggy Set Up Station RUF-VK Nitro Off-Road 22 08-13-2009 12:01 PM
mugen prospec steering problems!!! bajamike207 Nitro Off-Road 12 03-13-2009 05:01 PM
Let's Build a Schumacher Mi3! AdrianM Electric On-Road 265 01-07-2008 06:19 PM
