replacing shocks and differential fluids...
i ordered some shocks and differential fluids so i can replace the ones that came with my Jammin X1... i was wondering if i need to take them completely apart and clean them thoroughly before putting the new fluids in them... if i need to clean them, what sort of cleaner do i use...?
if you notice they are low on fluid that means you would need shock rebuild kits ...i have an x1crt so i know that the shock rebuilds are not that expensive and are easy to rebuild .....
on the diffs ...they are not as easy ....the fluid in them gets really gummy ..when i replace my fluids in the diffs ...i use naptha ...you can buy it in the paint section at lowes homedepot ....it will cut the grime off the internal diff gears ...remove all the cross pins and spider gears ....then the planetary gears ....i use a diff dunker ....(gmk supply on amain) ,,,,,,soak them and then clean them off ...re install and then if you have extra gaskets for the diffs ...then i would replace them as well ....then refill them 80-90% to the top and reassemble ....i usually replace the o-rings in the diffs about every 2 race days .....if you do replace the o-rings .....make sure to hit them with like green slime (team associated) or like shock snot(gmk supply) ...it makes them nice and plyable and they will last longer ....obtw if you do rebuild the shocks ....make sure and hit the o-rings in there with green slime as well ......hope that helped ....
there are many different things that you can use to clean the diffs.. i just use a mixture of alcohol and a lot of shop rags..
and if your not making an A-main order any time soon.....the GMK diff dunker is basically a Tea dunker......or a Tea Infuser if your lookin online...as typing in Diff dunker gets you No where fast.
http://www.amainhobbies.com/product_...ducts_id/12332
obtw here the link of the google search for diff dunker ...so it my get you something
http://www.google.com/search?hl=en&q...unker&aq=f&oq=
yup you can go that route ...and you can also go broke on shop rags ...trust me alcohol sucks for cleaning diff fluids out of gears ....use the naptha one time and you will never go back ....
and integra heres your link for that ...cuz i mean theres no tellin what you get on that search ....
http://woodworker.com/cgi-bin/fullpr...FQRkswodrjqy2g
i have always used alcohol and shop rags... rags are free from my work so no worries!!
yeh but only queers no what a tea infusser is ...lol.......jk ......i should have put a link ,.....
No when a buddy's trying to find one NOT at A-main..IE locally.....and its not like GMK calls it the diff dunking Infuser...so therefor i needed to do some research to find out what the actual name of these darn things were.....also why i said search Infuser Not diff dunker.
they're tea dunkers... i saw one at Walmart but it had a small chain instead of a stiff holder... i prefer the stiff holder as it will be easier to swish it around in the Naptha...
i'm using break/clutch cleaning spray to remove any kind of oil, grease or silicone.
hey bro does that stuff eat the o-rings up ? just curious ...i used to use a product called I.D.RED ......made by a company called zep....we used it on drive packs on copiers ...works like a champ ...but i have a new empoyer now and cant get it for freesucks its way expensive ...but will cut the worst mess you got
Naptha.....mmmmmmmm.........carcinogens.......benz ene............yummmmm
Bed, Bath and Beyond has the same exact tea/diff dunker. Bed,Bath its $3, GMK supply $7. And no i dont shop there, my wife does,lol
