Old 11-02-2008, 08:24 AM   #1
Trader Rating: 35 (100%+)
Default rb s3 turned into a 5 port
I was wondering if the go tech 5 port piston and sleeve rebuild kit could be dropped into the rb s3 motor??? My brother ran his s3 this weekend and got it around 380 degress some how...it was running 250 all day and the last round of practice it got very hot.....not sure why going to check on this later. thanks guys!
losiracer22 is offline   Reply With Quote
Old 11-02-2008, 08:57 AM   #2
Integra's Avatar
tune changes throughout the day u know.....as u stated....ran good all day till the last round....probably later in the afternoon.....the weather probably cooled down and the motor needed more fuel to compensate....u didn't give it....so it went lean.
on the P+S question....i think i remember hearing what your talkin about....and RB guru should chim in sooner then later.
Old 11-02-2008, 09:45 AM   #3
omarwashington's Avatar
I have the RB S3. Been using it for about two months now. Itís a great engine. When it is time for a rebuild I was reading up on some stuff about it.
Here is what I plan on doing.
Info from undergroundrc.com:
1) Exchange the crank for the S5 (it has a turbo cut into the crank)
2) Port the Intakes on the sleeve to gain additional to top en and run time
3) Run an RB #5 glow plug or a medium hot plug instead of the medium #6 plug once ported.
Undergroundrc.com has a porting video
omarwashington is offline   Reply With Quote
Old 11-02-2008, 09:46 AM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
I have heard it works but don't know for sure.
A whole new S3 doesn't cost much.
Are you sure it needs a new P/S? 380 is high but it's a tough motor.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-02-2008, 10:02 AM   #5
Tree's Avatar
Send a message via ICQ to Tree
I know that the Go Tech internals work for Novarossi engines. I'm not too sure about RB mills. PM 22Racer. He has had good success putting Go Tech internals into other engines.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 11-02-2008, 10:57 AM   #6
wingracer's Avatar
Why not just cut the so called "turbo port" into the s3 crank? It works great.
The best thing you can do to the sleeve is to raise the exhaust port. Duration is really low on the S3's.
Team Shepherd USA
Old 11-03-2008, 10:31 AM   #7
RBMike's Avatar
I don't know about the Go-Tech but the RB S5 piston & sleave will fit & then you will have your 5 port.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 11-03-2008, 12:12 PM   #8
Gary NJ's Avatar
Won't work - the GO parts fit the long stroke NR-based engines like the P5 and the 2001BF, but not the short stroke NR-based motors like the S3, S5 and S7.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 11-03-2008, 02:35 PM   #9
scrappy's Avatar
Not to mention the indexing notch on the sleeve... Go and NR are on the intake side... RB is on the exhaust side.
scrappy is offline   Reply With Quote
Old 11-03-2008, 07:13 PM   #10
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
so will it fit in the t21bf?
jamminnay is offline   Reply With Quote
Old 11-03-2008, 07:52 PM   #11
What about the RB S5 or S7 internals in a T21bf? If the RB's and 21BF are both short stroke shouldn't that work? Would you just be able to cut a indexing notch into the opposite side of the RB sleeve and install it in a 21BF?
x195svt is offline   Reply With Quote
Old 11-03-2008, 09:31 PM   #12
The RB S3, S5 and S7 all have compatible internal parts. If you want the best combo you will install an S3 piston and sleeve in a black coated WS73 case, with a turbo button. Also the S5 crank in a ported S3 is insane for usable power, and feels much like an OS speed. I've run combos of all the different RB parts, and like the modded 3 port the best.
CarCrazy is offline   Reply With Quote
Old 11-06-2008, 05:06 PM   #13
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i've seen tnt mods s3's and they fly, $180 motor + $100 mod is a great deal for the performance, and it will last a long time too.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
