Old 11-01-2008, 03:03 PM   #1
chad24's Avatar
Default ST-RR Gearing
I was wondering what changing the diff gears in the ST-RR to the 777 buggy style with the 13t bevel gear would change for speed and acceleration. The 13t gear is a little bigger then the sprial cut 10t stock gear, so I think it would increase top speed and slow acceleration. The crown gears seem to be the same size. So how much would this affect gearing and would droping a size or two in the centre diff spurr gear correct this.
chad24 is offline   Reply With Quote
Old 11-01-2008, 03:10 PM   #2
jaylude22's Avatar
Trader Rating: 93 (99%+)
I can't see this gearing change being being a positive one. By changing to a buggy's diff gearing(13/43) vs. truggy diff gearing(10/43) you'd eliminate any usable acceleration. In order to correct the gearing change, you'd have to go to a much larger spur gear, not smaller. Larger spur gear means moving throttle servo outward and up, neither of which are a good thing.
jaylude22 is offline   Reply With Quote
Old 11-01-2008, 03:37 PM   #3
chad24's Avatar
Is there a 10t bevel gear that will fit the buggy style crown gear? I tried a helfire one but the gear pitch is a little off.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
High Velocity Racing johnny boy Team and Company Discussions 976 06-29-2013 01:30 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
VENDETTA BL motor reviews.. pros/cons jaejw1 Micro and Mini Scales 121 02-09-2011 04:37 AM
