Old 11-01-2008, 02:55 PM   #1
Default Flywheel help please?
ok guys...so i'm breaking in my engine...on my third tank i notice something weird as i pull my rc10gt up to me to check the temp. I hit about 1/4 throttle on the way up...then about 1/2 for a few seconds. Well, i notice the speed did not increase, but the flywheel was spinning like it should be going MUCH faster. What do i do?
Ma-Deuce is offline   Reply With Quote
Old 11-01-2008, 02:57 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
check your slipper setting... if it is slipping it your speed will not increase..
jamminnay is offline   Reply With Quote
Old 11-01-2008, 02:59 PM   #3
sorry, but what is the slipper setting?
Old 11-01-2008, 03:39 PM   #4
jamminnay's Avatar
do you have the manual for the truck??
Old 11-01-2008, 03:42 PM   #5
jamminnay's Avatar
if you need a copy of the manual go to teamassociated.com... you click on support then downloads and scroll down to the rc10gt and you can view and print the manual there. hope this helps you out!
Old 11-01-2008, 03:42 PM   #6
umm, yeah lol
but i just went outside to run all the fuel out of the truck, and i squeezed the throttle the slightest bit because it was taking forever...well, i noticed that the rod connecting to the tire from the chassis was spinning on the left wheel..but the tire was not turning, and on the right side neither were spinning
Old 11-01-2008, 03:43 PM   #7
jamminnay's Avatar
check the wheel pins and see if they are still there
Old 11-01-2008, 03:45 PM   #8
where are those located?
Old 11-01-2008, 07:06 PM   #9
buckeye34's Avatar
pull the rear wheels off and if you notice, the rear wheels are keyed. there should be a pin going through the stud where the wheel goes on the truck.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Inferno MP9 thread captain america Nitro Off-Road 20015 05-19-2017 02:14 AM
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 04:53 PM
Force .28 Problems. Please Help BlackSS Nitro Off-Road 18 06-28-2009 04:58 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
