TOO MUCH MOTOR?!?
TOO MUCH MOTOR?!?
Is it possible to have to powerful of a motor in a truggy that you will have driveline problems? Reason I ask is today at a race a friend of mine has gone through 3 complete center diffs and is blowing them in 5 minute qualifiers. He has a new LRP .28 Truggy motor. He went through 2 stock diffs and one diff from another brand truggy just to see if it held up and it did not. He is not new at shimming diffs and they look shimmed right. Some guys have said it is too much motor that the LRP is Crazy and is causing the failures. 3 other of the same truggies out there with no problems and no others I have heard of have had that same failure. What do you guys think?
Eeeehm... must be something wrong with the truggy You cant work throug 3 center diffs with any engine... Maybe if you run brushless with a NEU or something but with a regular nitro engine, no, I think the problem is the quality on the drivetrain. Ever tried to change the center diff to another one? Buy the Xray XT8 one and you will not be disappointed.
do you know what weight silicone he's using? may not be filling it up? sounds like he's generating too much heat in the gears and they are breaking under the stress..
It is a Caster K8T. There are 5 of us locally running it and 4 of us are just fine. He just got it and was only his second time out with it and was just weird. I had a friend with a OS .30 on his ST-RR and could not keep the driveline together at all. Went down to a .21 and not a problem since either.
Chris maybe with the bigger motor he has to run a different ratio, different tooth clutchbell and spur. it is worth looking at since he obviously paid good money for the motor. maybe the ratio he is running is turning the rpms to fast causing the center dif to burn up.
ok
tell your friend to put about 15 to 20 thousand in the center diff but dont over feel it what is happaning is he os over feeling it and it is making alot of heat in side the diff already and when you over feel it there is not any room for the heat to exspand these diffes in the cars are running about 150 degrees or more after a 5 min qual so feel is about 40 percent less than what he was normaly doing and a little grease aroung the inside of teh diff house and gears never heart anything.
i am sure that the diffs are just not being filled properly.. .i would also check the bearings on the outdrives and make sure they are good..
Make sure the front and/or the rear brake is not dragging. Also, check the front and rear drive train to make sure nothing is locked up or wrong there. If there is tension in either the front or the back drive train including the brakes, then the center diff gears will be spinning alot causing extra heat and wear.... good luck
