Old 11-02-2008, 03:27 PM   #16
TC3ElectricGuy's Avatar
how much slack is between the bell gear and the spur gear. if it's too lose it could be slapping the gears and breaking the internals.
also, what is the condition of the front and rear diffs?
Team Losi 8ight 2.0
Axe Cobra X1 Evo .21 engine
Axe 2050 pipe
TC3ElectricGuy is offline   Reply With Quote
Old 11-02-2008, 03:34 PM   #17
vnmsgt's Avatar
The front and rear diffs have been perfect. They have been pulled apart and checked. Nothing wrong with them. Just the center.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 11-02-2008, 09:58 PM   #18
buckeye34's Avatar
that just leaves the center diff. not being filled up or the diff leaking...shouldnt be too much hp just my .02
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 11-02-2008, 10:38 PM   #19
Trader Rating: 42 (100%+)
Another thought...make sure when he is landing his throttle is not pinned. A .28 landing wide-open is going to put some stress on something. Though it is more likely going to cause frt. or rear problems, there is always the off chance.
Is his clutch bell showing signs of overheating? Does he have good carrier bearings on these center diffs? The bearing(s) could be binding and causing this.
All the other suggestions previously mentioned make more sense, but I have seen some strange stuff with these toys.
Hope this helps
mracer is offline   Reply With Quote
Old 11-02-2008, 11:41 PM   #20
Darin Z's Avatar
If all else fails, I'd make sure the front and rear diff, ring and pinion are the same ratio? Never know??? I dont know if Castor runs different truggy gearing/buggy gearing but that will trash a center diff fast.
Darin Z is offline   Reply With Quote
Old 11-03-2008, 06:04 AM   #21
vnmsgt's Avatar
Yes they are the same ratio for the front and rear. He will be bringing his stuff over today so a couple of us can take a good look at it.
Old 11-03-2008, 09:48 AM   #22
razzor's Avatar
Chris id suggest going up on the diff oil.
With the bigger motors the diffs take a lot of punishment especially the centre and unlike a .21 powered truggy the need the thicker oil
Id suggest 20k.
When he ran his truggy was teh front wheels ballooning a lot, that would also confirm that the center diff oild is too thin.
Have seen this happen on a few Mugen and X1CRT truggies.
Also make sure there is no drag on the driveline and the brakes are not binding.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-03-2008, 04:34 PM   #23
vnmsgt's Avatar
Well I think we found the problem. After almost 2 hours of messing with his center diff, we used a new diff housing, all new internal gears and it would still lock up in your hand, we even put 3 thick gaskets on the ring gear and it still locked, like it was really stiff. I took it apart myself the last time to look at it and I found the large washers behind the crown gears are mis-machined. They are thick as hell. If you put about 5 regular large shims together it would equal one of these shims. Both were like that. Just trying to break the diff in with drill it got very hot before. Now the Diff is nice and smooth and spins really free.
Will see wed. when he practices. I removed the center Diffs on my 2 K8T's and they felt exactly the same so I think he will be fine.
Old 11-03-2008, 06:02 PM   #24
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
Likely the problem.
My experience is that the front/rear diffs will go much sooner than the center diff if it's an issue of too much engine power...
I put an entire season on my center diff in my CRT with a Picco .28 followed by a JPX .28, both arguably have more power than the LRP... Never a single center diff issue though I did blow through about 5 rear diffs But those were also due to my negligence and not the engine itself.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-03-2008, 06:16 PM   #25
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
run 20-20-5 in the diffs. with the center diff heating up sounds like the center is a little light. if the rear is really light this could cause and issue also. like the others suggested check all rotational pieces for binding or siezing.
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 11-03-2008, 11:43 PM   #26
razzor's Avatar
Chris that would explain it and sounds like your problem is solved.
Casterracing ZX1.5R
Ofna Hyper8 stingray schmelme Nitro Off-Road 804 07-13-2011 09:45 AM
220mm GPR Class Arboleda Nitro On-Road 108 01-04-2009 07:24 PM
Did nitro hurt the hobby??????? TCRacer101 Electric Off-Road 64 09-09-2008 10:37 AM
2007/8 Midwest All-Star Carpet Series Kevin K Wisconsin & Illinois Racing 616 04-20-2008 05:14 PM
Speedpassion Brushless. razzor Electric On-Road 928 01-22-2008 08:27 AM
ROAR B/L motor Rules debate thread C_O_jones Electric On-Road 1080 01-21-2008 07:00 PM
Motor Magnet Zapping and Rebuild/Dyno Services Marcos.J R/C Items: For Sale/Trade 71 06-05-2006 10:23 AM
