Old 10-31-2008, 09:56 PM   #1
Default engine tuning question: still too lean...?
i think i got my engine tuned but every time i clear out the fuel by running flat out for a few seconds and then come to a complete stop, the engine will sound as if it is idling too lean... this only last for about half a second to a second and then it goes back to sounding tuned... do i need to richen the LSN or HSN some more...?
flipteg is offline   Reply With Quote
Old 10-31-2008, 10:01 PM   #2
First guess would be a too lean HSN and a fat LSN. What are your temps at the end of the tank. Sounds like you've fallen victim to a "false idle". Which basically means your idle gap is open to far but is being compensated by excessive fuel in the carb.
Furadi is offline   Reply With Quote
Old 11-01-2008, 12:11 AM   #3
hi, i just realized that i had 2 spacers in place for the glow plug... i changed my glow plug today and as i usually do, i left the spacer in the heat sink so i don't have to turn the car upside down every time i take out and reinstall the glow plug... the thing is, the new glow plug that i installed has a the spacer that doesn't come off the glow plug and i completely forgotten about it...
would have 2 spacers there contribute to this problem...?
Old 11-01-2008, 01:12 AM   #4
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
yes...lol having 2 washers will lower your compression a lot, causing you to over lean your engine looking for power. i would fatten her up and make sure you have only 1 washer under ur plug.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Head Clearance 54 Onroad Nitro Engine Zone 13 03-24-2010 02:02 PM
I need advise on pinch test/tunning... Mpowerz Nitro Off-Road 28 01-16-2008 12:36 PM
Engine tuning question - sputters at high RPM but plenty of smoke Arboleda Electric Off-Road 7 04-18-2007 08:49 AM
Engine Flame out issues. Please Help. rodneybarrett Onroad Nitro Engine Zone 24 07-04-2004 08:37 PM
