Old 10-31-2008, 11:22 AM   #1
Default ninja jx21 problems
got my engine tuned by a local hobby shop ran great for a while. Ever since the weather got colder it started running crappy and started turning off. now its running great to me but having lots of trouble starting it after running it notice it starts easier with the air filter off and also notice lots of fuel spitting out the carb i guessing its rich but like i said it runs great while running please help.
ccordero85 is offline   Reply With Quote
Old 10-31-2008, 11:32 AM   #2
jrock32's Avatar
Send a message via MSN to jrock32
Im not sure if this will help, but does the slide open and close easily? Mine was very tight and would stick....causing all types of problems. I had to take the slide out and use a scotch bright bad then a buddy filed it down in one of the grooves. There must have been a little burr in there cuz its very smooth know and runs great! I was a little bumbed about the motor at first, although Im very impressed now.
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 10-31-2008, 12:04 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
First of all! don't ever start your engine without an air filter.
the reason it's hard to start when it's warm is the piston expands as soon as you hear that very first pop. when the engine is fully broken in it will start much easier.
You should read this entire thread. http://www.rctech.net/forum/nitro-of...ugen-jx21.html
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-31-2008, 01:45 PM   #4
mugenb46's Avatar
and also, heat it up before evry start with it being new, and the tune or air fuel ratio will change from afternoon to evening, during the evening the air is so clean it will cause the motor to lean VS afternood running when the air may have more humidity=dirty air, also what plug are you running, if you run in low himidity try using the OS P6 or cooler, clean air running doesn't require ultra hot plugs.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 10-31-2008, 02:10 PM   #5
22Racer's Avatar
Trader Rating: 67 (100%+)
Even stock cars that run on alcohol have trouble staring in cold weather. Heat up the motor with a heat gun and it will fire right up.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 10-31-2008, 03:43 PM   #6
engine has been fully broken in with 8 full tanks of gas...my seems to be opening and closing perfectly fine, plus im using a p3 os ultra hot plug...the main problem I'm having is the car won't start after I turn it off and it's off for no more than a min with engine already warm...I notice that gas spits out of the carb during cranks and the reason why I take out the filter is because it seems that the gas spits out in the filter and then drips back down in the carb causing it to flood
Old 10-31-2008, 05:24 PM   #7
stump27's Avatar
when you stop it and its a little warm, the fuel inside the engine will boil out. thus acting out of fuel when trying to start. try unhooking the pressure line from the pipe and blow through it and watch the fuel go to the engine. then start it. should help.
stump27 is offline   Reply With Quote
Old 10-31-2008, 05:37 PM   #8
vladconnery's Avatar
Trader Rating: 35 (100%+)
8 tanks of gas do not = fully broken in. When you have ran a 1/2 to gallon of fuel through your engine it's fully broken in.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 10-31-2008, 06:16 PM   #9
moeman's Avatar
Trader Rating: 26 (100%+)
Nm
moeman is offline   Reply With Quote
Old 11-01-2008, 06:01 PM   #10
the engine has about 1 1/2 gallons of fuel through it. well today i took it to my fav hobby shop and to them it seems to be the con rod. it runs fine when on just takes foe ever to start after its been on they said it has play and thr kid who told me that is the engine builder kid at the shop and hes also a nat racer so im guessing he knows what hes talkin about but we'll see.
O.S. Speed owner speak up NitroNewbie Nitro Off-Road 97 03-07-2010 12:37 PM
OS Speed vs. The new Ninja JX21 CarCrazy Nitro Off-Road 121 10-14-2009 06:31 PM
GRP .21 VS Ninja jx21 xpertpredator Nitro Off-Road 13 12-09-2008 06:00 PM
sorry to do this Megacrash Nitro Off-Road 78 09-29-2008 04:31 PM
