Old 10-30-2008, 09:24 AM   #1
Send a message via MSN to nenderle
Default Starter Box Question
I recently purchased an OFNA chrome top starter box from my local hobbytown. I've used the thing 4 times total.
Here's the link to it that I found: http://www.amainhobbies.com/product_...oducts_id/5429
My question is however, I use the starter box for a minute or so and the motor becomes very hot and loses it's torque. It will spin the motor but it won't spin the flywheel. My question is do you think that I have a bad motor in it? My plan is to take it back today, but I wanted to check to see if it is normal to run for only a minute or so before the engine becomes very hot and loses torque?
nenderle is offline   Reply With Quote
Old 10-30-2008, 09:39 AM   #2
I should also add that I'm using it to start a Losi 8 Truggy. This could make a difference I'm sure. Although the owner of the store knew I had this vehicle.
Old 10-30-2008, 09:47 AM   #3
looneytune's Avatar
Trader Rating: 23 (100%+)
My guess is your hitting the chassis more than the flywheel. Make sure there isn't rubber near the slot for the flywheel. I beveled the opening on both my Losi's for extra clearance. It needs to be aligned correctly and also make sure the motor starts early enough so it isn't rubbing the chassis by the time it starts spinning.
looneytune is offline   Reply With Quote
Old 10-30-2008, 09:48 AM   #4
revo61's Avatar
Trader Rating: 18 (95%+)
Make sure the nut that holds the starter wheel on is tight. It is very hard to tighten. If the wheel is slipping it can cause the motor to overheat.
revo61 is offline   Reply With Quote
Old 10-30-2008, 11:21 AM   #5
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
definetly check for rubs...
jamminnay is offline   Reply With Quote
Old 10-30-2008, 11:37 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
The slot for the flywheel in the Losi chassis is smaller in both width and length. I had the small OFNA box with a smaller wheel... I "tapered" the wheel with a file while spinning the box over with the motor to get it to clear properly. I didn't modify my chassis, but I took quite a bit of rubber off the wheel to get it to fit. (I used to run a Losi buggy)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Losi starter box rgrassey@me.com Nitro Off-Road 151 05-16-2011 03:09 PM
starter boxes losi_racer Nitro Off-Road 19 06-08-2009 01:39 PM
another nitro starting question muz18u Rookie Zone 6 10-11-2008 08:46 AM
Future of Nitro On Road Racing genesisG4 Nitro On-Road 67 01-31-2008 06:03 PM
lipo RX packs and spectrum Jason Halvorson Nitro Off-Road 19 01-22-2008 08:08 AM
Mugen Starter Box question? drrm123 Electric Off-Road 7 05-19-2007 07:46 AM
