Old 10-30-2008, 02:15 PM   #16
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
GO Engines 6 port .28 + GO Engines 0801 Pipe
10 minutes and 15 seconds before flaming out ...
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 10-30-2008, 08:52 PM   #17
Trader Rating: 42 (100%+)
What kind of run times can you expect from a typical .28 - all things being equal? I am thinking about buying a .28 for the heck of it and need it to go 7.5 min at least.
Thanks in advance guys
mracer is offline   Reply With Quote
Old 10-31-2008, 04:09 AM   #18
Originally Posted by Tbone Revo View Post
I would say it could be done. I have seen modded v-specs run 13+ mins in truggies but I dont think you will get ten min with the GRP. I know people that are having trouble getting 8 mins out of the .21s.. I dont know if it is the motor or the drivers, maybe some people that run GRPs can chime in. I am also looking at the GRP .28 but I am not trying to get 10mins out of a tank. JMO
I know this is off topic but I get 10+ mins out of my AB mods v-spec and also have never had a .28 pull me (that was straight motor not driver error) . get a v-spec send it to Adam Blevins and you wont be dissapointed
biker56556 is offline   Reply With Quote
Old 10-31-2008, 04:19 AM   #19
PowerHouse's Avatar
Trader Rating: 66 (100%+)
My turbo cranked Picco P3-28's are getting close to 12 minutes in a truggy. We found out the hard way at Tillsonburg earlier this year. It was running the stock 9mm insert. My OS .28 XZ are getting 10 plus and my N528 was getting close to that as well so it is very possible to get run times on them, you just have to know how to extract it.
PowerHouse is offline   Reply With Quote
Old 10-31-2008, 05:31 AM   #20
allan42r's Avatar
Originally Posted by jamminnay View Post
well it was at an rc pro race and he passed tech.... soooo he was not over on capacity. smooth driving always helps!
my car went thru tech this year at a pro series race and got the ok, my teammate was right behind me didnt pass with the same car,tank,fuel line,length. even if his car would of passed no way his style would get 10min.lol
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 10-31-2008, 05:34 AM   #21
allan42r's Avatar
Originally Posted by wingracer View Post
Well, a 5.4mm restrictor, 16% nitro, 3xxx numbered pipe, 15 tooth clutch with light springs and a smooth finger would probably go 10 minutes. Don't know if it would be fast though.
+1 with the 5.5 restrictor in a 28!
i hear hara won some race with a 5.5 in his speed.
Old 10-31-2008, 05:36 AM   #22
Akhor's Avatar
I would not even bother trying to get 10 minutes. It may be possible but I the way you have have to drive would probably put you in last..
Akhor is offline   Reply With Quote
Old 10-31-2008, 05:40 AM   #23
Trader Rating: 27 (100%+)
In my opinion it is hard to just say that a certain engine will give you a certain runtime. As indicated by some people already, the driving style has a lot to do with it. But also the track itself has a lot to do with it! A couple of weeks ago I ran 13 minutes on a tank with my RC8T with V-Spec on an indoor track. The next day I was outdoors and with the exact same setup I got 8 minutes on an outdoor track....
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 10-31-2008, 05:49 AM   #24
allan42r's Avatar
Originally Posted by Revo-daddy View Post
I know this is very subjective but I am looking for real world experiences.
I am picking up a ZO1-T and thinking of getting a GRP .28 tuned. I know I could use the .21 but I've always wanted a .28. I plan to run it with a 6-7 mm spacer and a 053 pipe and being gentle on the throttle. My track will be doing 10 minute mains, if we don't have mandatory pit stops I'd like to play the fuel mileage game. In which case I would get the .21.
your lap times willbe better over a ten min. main with a 21. tried to run one early this season. not many experts run a 28, mostly sportsman.
a 10 min. main doesnt really mean you are going to run for EXACTLY 10min.
does your clubs race clock start when you take off or when you cross the scoring line? and at the end of the race say you cross the line at 9.50 and you still need to finish the last lap = 10.30 race.
i understand your thought here but really a pit stop is about the same as 1 crash. get the motor and pipe you really want and pit stops are good practice so when you go to other tracks,bigger races you willbe ready. you can make a little time in the pits or loose alot!
Old 10-31-2008, 07:04 AM   #25
I didnt think of that, your right most of the races are longer than the main time. I think I'll do OK with the 28, I may just put in a small restrictor for club racing then uncork it for the larger tracks in my area. There are a couple tracks near me where you need some serious power, and I'd rather not have to extract every bit of out a .21
Revo-daddy is offline   Reply With Quote
Old 10-31-2008, 07:46 AM   #26
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i think i will just stick with the .21
jamminnay is offline   Reply With Quote
Old 10-31-2008, 08:16 AM   #27
Euro Stealth's Avatar
Everyone I see racing in Florida, and we have some fairly wide open tracks, and everyone runs a .25 at the most. Anyone that is running pro truggy is running .21's that are modded, and they have no problem with stuff. I have seen guys Quad a 25ft section in a truggy with a .21 and that section has a 10ft runway from a corner. So I think if you get the right .21 you would have no problem.
My suggestion would be a Pro Twister Mods Go Tech .21 7p race. It will be about $269-$289, won't kill your pockets, even for a modded motor people are still getting 8+ gallons out of them, and it has just as much power as the $350-^ motors have.
Just my .02cents
Euro Stealth is offline   Reply With Quote
Old 10-31-2008, 10:24 AM   #28
allan42r's Avatar
+1 and find a pipe,motor,clutch setup you like and dont be going back and forth on restictors. the way the power and diffs work together you would be better off running the same setup and then just worry about suspension and tires.
Old 10-31-2008, 10:43 AM   #29
Maximo's Avatar
my opinion is a modified JPX 21 .... extremely powerful, as much power as many 28's, but with runtime of a .21........ I own every worthwhile .21 and nothing carries the snap crackle and pop the modded JPX does......
Maximo is offline   Reply With Quote
Old 10-31-2008, 11:21 AM   #30
Maximo have you tried the jx-21? If so what are your thoughts?
NORTHWEST 1/12 Q&A! STARSCREAM Northwest Racers 181 02-12-2017 06:48 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Werks Racing b3 pro pwnzor Offroad Nitro Engine Forum 71 09-29-2011 03:46 PM
Malaysian National Championship (MNC) 2008 KoE Malaysian R/C Racers 769 01-04-2009 08:35 PM
Winter Champs contact Australian Racing 592 07-07-2003 11:04 PM
