R/C Tech Forums (http://www.rctech.net/forum/)
-   Nitro Off-Road (http://www.rctech.net/forum/nitro-off-road-130/)
-   -   OS P3 Plug Problem (http://www.rctech.net/forum/nitro-off-road/250497-os-p3-plug-problem.html)
joydude630 10-29-2008 01:01 AM
OS P3 Plug Problem
Hey guys,
I got over 5 gallons on my OS Speed. The compression is very good. But I faced a problem for the first time with the P3 plug. The plug was 80% dead in just 7 tanks. I was not running lean either.
Please advise the nature of the problem. Thanks.
jpalessi 10-29-2008 01:04 AM
Originally Posted by joydude630 (Post 4990665)
Hey guys,
Did you run out of fuel on power?
porkchop 10-29-2008 01:36 AM
Hey guys,
cheek the bearings in it :nod:
joydude630 10-29-2008 02:14 AM
Nope
joydude630 10-29-2008 02:15 AM
Bearings are fine
BSC 10-29-2008 02:55 AM
I've had problems with the last couple of batches of P3 plugs . They just don't work but read as fine :nod: I don't know what has happened to them but everyone i know has had the same thing . There must have been a bad batch come through ;) I could be wrong but i tried another brand plug after spending a fortune on the motor and it fixed it .
sand geek 10-29-2008 08:49 AM
that could be uncomfortable
backwoodsRC 10-29-2008 07:45 PM
same
i also have had the same prob. with p3's.. only 2 left on sheet pm if you find out the prob..
wingracer 10-29-2008 08:00 PM
Have you replaced the rod in those five gallons? If not, do so NOW.
DirtyDezPirate 10-29-2008 08:38 PM
ive had problems with the new P4 and P5 as well.. not even running my engine at all.. i had to replace for another new one.. it works.. looks like OS is having issue with some;
Jaz240 10-29-2008 08:42 PM
OS? Issues? No...it's all your fault! or mine, or his, or anyone but OS, they never have issues, and when they do, it's still your fault, and your problem...man I need to let it go, can you tell they wronged me?!
joydude630 10-29-2008 09:59 PM
I haven't replaced the rod yet.
I started the my buggy with a new P3 plug and I changed the HSN to 3 which is the stock setting. The engine started right away and after few seconds it shut off. The I changed the HSN setting 2/1/2 and the engine started and after few seconds shut off. There was a loud spinning sound from the clutch area when ever the engine was shutting off.
jpalessi 10-29-2008 10:12 PM
Idle gap: 1 turn from just closed
HSN: 2-1/2 from closed
MRN: 3-1/4 turns from closed (flush)
LSN: 4-1/4 turns from closed
If your idle gap is not set correctly, you will just chase the tune. set it at 1 full turn , and leave it.. use the LSN to stabilize the idle
joydude630 10-30-2008 06:34 AM
Thank you very much for the needle settings.
What are the other causes of a glow plug dieing too early?
jpalessi 10-30-2008 10:24 AM
to lean, running out of fuel on power, and debris..
does or has the engine backfired?
Content © 2001-2011 RCTech.net
