Old 10-30-2008, 11:25 AM   #16
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by joydude630 View Post
What are the other causes of a glow plug dieing too early?
Originally Posted by jpalessi View Post
to lean, running out of fuel on power, and debris..
does or has the engine backfired?
And stretched rods or loose bearings but sounds like this could be a tuning or plug problem.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-30-2008, 04:13 PM   #17
t0adman's Avatar
What does it mean if the engine backfires?
I've had some trouble with P3s lately. They say they're fine but they run horrendously. When I swap in the new one it's all better....for a while.
t0adman is offline   Reply With Quote
Old 10-31-2008, 02:17 AM   #18
Thanks guys for the list of problems.
I was at the track today and my buggy was running fine. No issues with tuning or plug.
Just noticed one thing today. When I am the air, the engine revs a lot when the buggy is in air. Is it a sign that the fuel is getting over? Just curious.
joydude630 is offline   Reply With Quote
Old 10-31-2008, 02:20 AM   #19
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
to lean on the low end!
or the idel to high
rule for idel
the leaner the motor the lower it is
the fater the motor the higher it need to be
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 10-31-2008, 03:13 AM   #20
or the idel to high
rule for idel
Hey Porkchop,
Are you talking about the Throttle Stop Screw or the Metering Needle with regards to tuning on low end or idle to high as per the OS Speed manual? I hope I am making sense here.
Old 10-31-2008, 06:59 AM   #21
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Anytime an engine backfires.. It's timing. Usualy caused by a bad plug, or debris in the engine.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-31-2008, 07:33 AM   #22
jpalessi's Avatar
Check that there is no air or fuel leaks, carb, carb boot, f/bearing, ect...
if all is ok, and the needles are set to my above settings, then backout the LSN 1/4 turn.
Joe Alessi
www.Lucky7RC.com
Old 11-01-2008, 12:05 AM   #23
Hey Joe,
There was no tuning or over revving issues with my Speed for the first tank. Then the engine started over revving during jumps most of the time on the second tank.
When the engine was on idle, the sound wasn't' coming down. It was loud. Should I set the THROTTLE STOP SCREW which is the smallest screw on the engine and also richen the LSN?
Old 11-01-2008, 01:02 AM   #24
jpalessi's Avatar
Hey Joe,
Yes... The THROTTLE STOP SCREW your referring to is your idle adjustment.
With the car clean take off the Air filter, then take out the carb insert (red or blue velocity stack), then with your finger pushing the slide closed, look down the carb, and very slowly back out the idle adjustment screw just until you see the slide fully close, then go back in 1 full turn. now your idle is set. try that and lmk how it works out.
Joe Alessi
www.Lucky7RC.com
Old 11-04-2008, 03:59 AM   #25
Thanks for everyone's support and especially a special thanks to JPALESSI for helping me out. The needles on my engine are set now.
Old 11-04-2008, 06:26 AM   #26
jpalessi's Avatar
No problem joydude630! anytime!
Joe Alessi
www.Lucky7RC.com
Old 11-04-2008, 06:57 AM   #27
Rick Vessell's Avatar
Have you checked your exhaust and pipe gaskets? Tank lid seal? Fuel lines? Head bolts? All can cause an air leak and create an issue like you described. The back fire can also be from over rich settings to compensate for the air leak which will dump a large volume of fuel in the engine at start up.
Socko
Rick Vessell is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Punggol Off-road Track. Superb Singapore R/C Racers 9453 02-24-2010 09:26 PM
OS VSEC PROBLEM MaTt 93 Nitro Off-Road 26 01-21-2009 06:30 AM
Glow plug distortion? herb99 Nitro Off-Road 26 12-26-2008 02:47 AM
Hyper 8 Pro's Mach 21 engine issue.. viperviper Nitro Off-Road 7 06-04-2007 05:31 AM
