Old 10-28-2008, 07:16 PM   #1
CanyonCarverR1's Avatar
Default Standard plug vs. Turbo plug
Are the engines the same except for the head button?
CanyonCarverR1 is offline   Reply With Quote
Old 10-28-2008, 07:35 PM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
well since your questions is so vauge... if you get a turbo plug you need a different head button. so if you bought an engine and it said "turbo plug" or something then yes that would be one difference but the engine could be better built or something to make it a "turbo version" of the original
like the OS 18 TM and the OS 18 TZ, the TZ is supposedly faster and supposed to be turbo..
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 10-28-2008, 07:52 PM   #3
Rocket42's Avatar
The standard plug uses a copper washer to seal the combustion chamber like a ring on a full size spark plug. There is no taper to the plug and it leaves a big flat spot in the dome of the combustion chamber.
A turbo plug doesn't use a washer and relies on a taper at the bottom of the plug which is supposed to match a taper built into the head button. This is what makes a seal for the combustion chamber and is considered a better seal then the copper washer. Because the plug is tapered the flat part of the plug that is at the top of the combustion chamber is smaller and allows for a more domed combustion chamber.
The tigher seal and better shape of the combustion chamber will improve the engines performance and that is why most high performance engines today use turbo plugs instead of standard.
Rocket42 is offline   Reply With Quote
Old 10-28-2008, 08:14 PM   #4
Sorry...let me re-state my question.
I have a ton of turbo plugs and an engine that has a "standard" head button.
Can I just put a turbo plug head button on it and run it without any other mods?
Old 10-28-2008, 08:27 PM   #5
Rocket42's Avatar
Yeah you should be able to swap with the same mfgrs. head button without having to re shim
Old 10-28-2008, 09:06 PM   #6
pinky2252s's Avatar
+2 you just need a turbo button
Team Terribles
Old 10-29-2008, 10:34 AM   #7
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+3
jamminnay is offline   Reply With Quote
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
RB S7---Turbo Head vs. Standard Head TXRC8racer Nitro Off-Road 25 07-13-2009 09:18 AM
turbo vs. non turbo heads ehames005 Nitro Off-Road 34 02-24-2009 09:11 AM
