Old 10-27-2008, 12:04 PM   #1
DriftProjectR's Avatar
Trader Rating: 38 (100%+)
Default Jammin Setup questions
hey guys this last weekend i had a nasty run away. so im rebuilding my rig.
I have a Jammin Crt Pro with a OS V-Spec and 2050 pipe.
a buddy gave me his old BCe Pj2 chassis that he never used.
i'm going to do the small gear conversion and 16 mm shocks.
i was wondering if you guy had some good setups for the Diffs and shocks.
any information would work.
ALSO: does anyone know if the 48 teeth kyosho Center diff gear would work for the small gear conversion. the bce build requires the 50 teech kyosho center diff.
thanks in advance guys!
Hot Bodies IFMAR Worlds
OS Engines
Ace Servo
BCE Design
Bodies By Scott
Lungsford Titantium
M2C Racing
DriftProjectR is offline   Reply With Quote
Old 10-27-2008, 05:48 PM   #2
jamminbce's Avatar
Default jammin
50 tooth matches stock gearing. if you use the 48 i hope its a long track as youll change your gearing. 7-10-3 is a good starting point with diffs, depending on your track you might try a setup like 10-20-3 or 10-30-3. trial and error and you can start with the setup for the x2.
jamminbce is offline   Reply With Quote
Old 10-28-2008, 01:50 AM   #3
Joe_Racer's Avatar
Trader Rating: 31 (100%+)
You can also go to truggyracers.com to see what other guys with the PJ2 are or were using. Follow this link http://www.truggyracers.com/forum/index.php?showforum=57
you will have to register to access it but it only takes a second and you will be on the main site for BCE.
Jack G.
Mugen MBX-7 Novarossi Plus 4, Mugen MBX-6TR Novarossi P5
RC10 GT2 OS TG, RC10 B4.2 17.5, SC10 FT 13.5, RC10 T4.1 13.5
Joe_Racer is offline   Reply With Quote
Old 10-28-2008, 02:29 AM   #4
Trader Rating: 44 (100%+)
i went with x2 gears with 48 tooth center you'll have the same ratio as the new x2(diffs are 45/10 as opposed to hb's 43/10) yes the jammin is more expensive but I prefer to have all jammin and a slightly torque based setup
as for diffs I have 5/30/3 but thinking of trying 5/15/3 and see what that does for me
in the sbb's i have 45 wt with gry up front and 40 wt with blues(springs out back)
for the rest of the setup check truggyracers.com bce thread
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
Tamiya TNX 350LS1 Monster Trucks 1092 07-08-2014 10:42 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Ofna Hyper8 stingray schmelme Nitro Off-Road 804 07-13-2011 09:45 AM
Getting into 1/8 buggy racing. wheelman25 Nitro Off-Road 25 05-07-2009 02:38 AM
Jammin X1-CRT, Complete Race Setup Ready to RACE jfischer R/C Items: For Sale/Trade 7 06-05-2007 11:32 PM
