Old 10-27-2008, 02:51 AM   #1
Default Wear on rtr buggys as oposed to kit buggys?
Hi guy's, i have a kyosho inferno sports mk3, i had my first race yesterday and it was very wet and muddy. Stripped the car down this morning and found metal filings under the rear diff, the teeth have worn on the gears drastically and will all need replacing! Not only this but the shocks need a rebuild as the front's seem to have collapsed during the racing yesterday. There is also a small number of other bits i need that have worn.
My question is, would this amount of wear be the same on a higher end buggy for example losi 8ight etc? I'm only a beginner but don't really want to have to keep pouring money into a rtr buggy that will be worth next to nothing when i come to upgrading later on. I appreciate it's only a sport buggy and maybe i'm expecting too much from it but by the time i have bought all the genuine kyosho parts i need it seems a bit of a false economy to spend lots of money upgrading diffs etc when i can get a buggy such as a losi 8ight at a great price off the net!
Any views/opinions/help appreciated.
Thanks-Hugh
hugh_b is offline   Reply With Quote
Old 10-27-2008, 05:15 AM   #2
Trader Rating: 1 (67%+)
Its possible that your gears stripped due to landing with your throttle punched. As far as your shocks being rebuilt, you might of had too thin of an oil in them and too soft of springs causing them to wear quickly during the race. I bet if you tweak a few things you will get better durability.
I guess to answer your question though, you will most likely get better durability from a higher end buggy.
mbogosia is offline   Reply With Quote
Old 10-27-2008, 06:03 AM   #3
BAUSTIN's Avatar
i have a 7.5 roller setting in my garage collecting dust.......is has several hop ups on it, mainly a compleste set if cvd's (i didnt think they came on the rtr) all new ring and pinion gears(it was never races) k3 shocks.....id let id gor for 75$ plus shipping
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
