Help Pipe Questions..OS 2050,OS 2040
OK Here`s a questions for you guru`s.......Is the OS 2050 the same pipe as a OS 2040.....I know the 2050 is for offroad and the 2040 is for onroad but I heard he only difference was the manifolds......The 2040 has the onroad manifold and the 2050 has the 8th scale offroad typemanifold........My questions is the pipe the same..
I got my 2050 smashed today and am looking for another 2050 but they are discontinued....."IF" the 2040 is the same as the 2050 I can use my offroad manifold and be set... |
Originally Posted by rossoh10
(Post 4981039)
Thanks I`ll watch that item....I would really like another OS 2050 though.....
Don't confuse those two pipe sets. They are not the same design. The OS 2050 is not a Axe Rossi 2050.
Originally Posted by ezveedub
(Post 4981315)
Ok thanks...What about the 2040 to the 2050 minus the manifold is the exhaust the same |
(Post 4981315)
rossoh10, What engine are you using the OS 2050 on?
I'm not sure what the changes between the 2040/2050 would be, but knowing the 2040 is a on-road pipe, it will most likely favor less bottom torque with power topend power, but that may not be the actual results.
Yeah thats what I thought but was just wondering because the pipe looks exaclty the same except for the manifold
depending on your engine this pipe may be a great choice. It works well on the vspecs.
http://www.carolinasrc.com/Webstore/...idproduct=5120 |
