Old 10-26-2008, 04:48 PM   #1
Trader Rating: 8 (90%+)
Default Accociated RC8 Big Bores
I have a RC8 and want to install Associated BB shocks. I need the froms 29 and the rears 38mm set of shocks. Now for my questions?
are the shock standoffs the same as original that will work with the BB
I have a surplus of stock shock shafts, boots, shock ends and standoffsn will all of these trasfer over to the BB
where do I get springs or does anybody know when there coming out
what set ups are people running pistons, springs, oil etc
thanks
franklucas is offline   Reply With Quote
Old 10-26-2008, 04:50 PM   #2
jc99's Avatar
Send a message via MSN to jc99
Have a look at the AZ forum:
http://www.aeforums.co.uk/forum/index.php?showforum=10
Maitland Off-road Radio Car Club
www.morcc.com.au
jc99 is offline   Reply With Quote
Old 10-26-2008, 06:50 PM   #3
t0adman's Avatar
The AE Forums are a great resource. There's a ton of info, including from AE guys like Brent T., on the big bores, setups, etc.
In the meantime, the stock standoffs will work but you may or may not need the AE flanged lock nuts (part number in a post on the AE Forums). I use them but my buddy just used the blue plastic shock bushings and they've held so far. You may also have to grind the wing mount a little so the shocks clear. I used a Dremel and a sanding drum and took off about 4mm of material and it's working great. Boots will not cross over but you'll be happy with the new ones. Much better. Ends might cross over, haven't checked. AE springs should be out soon but the 16m OFNA springs work as well. I picked up the soft, medium and hard springs from OFNA. They also offer a very soft set (so I hear). The soft ones are plenty soft though. They're also painted different colors, which looks cool.
Check those forums for the setups. This is a particulary good post by Brent.
t0adman is offline   Reply With Quote
Old 10-26-2008, 11:44 PM   #4
I have them on the buggy now same stand offs. The flanged nut it's down inside theshock cap plus tuening the bushing around. Having to grind a little on the wing mount.
AE's forum will give all the info on doing it
pdmustgt is offline   Reply With Quote
Old 10-27-2008, 02:33 PM   #5
Trader Rating: 24 (100%+)
I found the shocks here but no springs yet. I think sommeone mentioned the ofna's which will work fine.
You may look on the front page of this site and see what coupons they might have.
http://www.carolinasrc.com/Webstore/...dcategory=1568
ABURTON is offline   Reply With Quote
Old 10-27-2008, 11:41 PM   #6
Yes ofna springs work just fine. I have the silver rear spring but still waiting on the front spring set. many places show they have springs then after you order them you find them on backorder. R/C planet got me
Old 10-28-2008, 05:26 AM   #7
One thing I like about Carolinas is that it shows you if it's in or out. I had that happen before as well...
Old 10-28-2008, 05:24 PM   #8
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
so does anyone know when the springs will be available??
jamminnay is offline   Reply With Quote
Old 10-29-2008, 09:30 AM   #9
kdub's Avatar
Silver and Black springs are available. The spring sets and bronze springs will be 2 weeks.
kdub is offline   Reply With Quote
Old 10-29-2008, 10:16 AM   #10
jamminnay's Avatar
awesome.. my car should be here any day now and i was wondering when all of the springs would be available..
Old 10-29-2008, 11:33 AM   #11
I should have said I have the AE rear silver springs. Now just waiting on the AE front spring set. Right now I have ofna spring on. I have to say the AE spring are by far cheaper price over the ofna springs.
You think they would have software showing what have on hand. Problem I called them gave them the part# the guy said they had them. I was placing the order online while I was talking to him. Then the order said backordered after placing the order but I get the big bore shocks they wasn't backordered. Called back got someone else they don't know why he said they had the spring set there when they haven't recieved them.
Old 10-29-2008, 02:02 PM   #12
-R2-'s Avatar
if you are looking for Ofna springs we have them in pairs also not just full sets, these are the parts numbers
41021 rear 16mm yellow super soft
41022 rear 16mm white soft
41023 rear 16mm blue (truggy med.)
41024 rear 16mm silver med.
41025 rear 16mm gray(truggy firm)
41026 front 16mm yellow super soft
41027 front 16mm white soft
41028 front 16mm blue (truggy med.)
41029 front 16mm silver med.
41030 front 16mm gray (truggy firm)
we have these part numbers in stock so call or visit your LHS to place your order.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 10-29-2008, 11:01 PM   #13
The one that are being talked about on AE was spring pack of front and rears
