Old 10-24-2008, 11:35 AM   #1
Default throttle return spring
hi guys can you tell me what is the best way of doing this type of mod i had a run away in my local park ending with my x1cr buggy going for a swim in the boating lake! and want to avoid any further mishaps any suggestions greatly apreciated by the way i am useing a spectrum dx2
cheers
spudly12 is offline   Reply With Quote
Old 10-24-2008, 11:53 AM   #2
revo61's Avatar
Trader Rating: 18 (95%+)
The spektrum has a built in failsafe, be sure to set that up. Use this for the throttle: http://www.amainhobbies.com/product_...ducts_id/23715
revo61 is offline   Reply With Quote
Old 10-24-2008, 12:02 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I simply wrap two small rubber bands around the carb. Wrap it from the fuel inlet nipple side and carry it over to the carb pull arm. Most LHS carry a bag of small rubber bands. The springs work, but if you mount it where it touches on the carb boot, they will eventually cut through them.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 10-24-2008, 12:10 PM   #4
cheers for the replies i did have a rubber band but it snaped and i did have the failsafe set up but the micro reciever failed which i think is why i had the runaway!
Old 10-24-2008, 12:15 PM   #5
Tree's Avatar
Send a message via ICQ to Tree
I use these:
http://cgi.ebay.com/71291-Goody-CLEA...QQcmdZViewItem
I bought a pack of these at a local Wal-Mart and they work better than a spring and rubber band in my opinion.
Once a spring has been stretched to far, it won't have the tension close the carb plus it is likely to rust.
Rubberbands will degrade after a short while and eventually snap or break especially due to the heat and fuel exposure. You definately don't want that to happen while you're running your rig.
The Goody elastic hair bands will not degrade, rust, or lose its tension. I use two bands on all my carbs. I wrap one around the carb opening and the slide carburetor ball linkage and another around the HSN and the carb ball linkage. One pack will last forever.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 10-24-2008, 12:28 PM   #6
im sold on them ill order them 2day
cheers
Old 10-24-2008, 01:04 PM   #7
ezveedub's Avatar
Here is another option with pics.
http://www.kyoshoamerica.com/techtips.php?techtip_id=5
Old 10-24-2008, 01:22 PM   #8
if u have a good hi torque servo then that little rubber band isnt gonna pull it bak
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 10-24-2008, 02:28 PM   #9
helivaguy's Avatar
Trader Rating: 42 (100%+)
has nothing to do with the servo....rubber bands work in case the linkage (ballend) pops off the carb.
helivaguy is offline   Reply With Quote
Old 10-24-2008, 02:30 PM   #10
Tree's Avatar
Originally Posted by ezveedub View Post
Those are the same as the ones I posted.
I use those little elastic bands with a Hotec 5955TG which is rated a 333 oz/in @ 6 volts. I am using a 7 volt regulator so I have a bit more torque and speed compared to the 6 volt rating and those little bands have held up well and pull the slid carb closed. They are the best and cheapest investment you can make in this hobby.
Team Holy Rollers
HiTec Servos
Old 10-24-2008, 02:32 PM   #11
man thats suprising
they are pretty much dental bands. i used to have a shit ton of them id send ppl for shipping cost but i dont got them anymore
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
8ight 2.0 RTR - Throttle Linkage and return spring b1alan Nitro Off-Road 15 03-11-2011 04:33 PM
What throttle servo ? joeling Nitro Off-Road 34 07-07-2007 12:09 AM
SON OF A B***H!!!!!!!!!!!!!!!!!! espo16 Nitro On-Road 31 07-02-2005 10:20 PM
