Old 10-23-2008, 08:50 PM   #1
Default Radio Electronics HELP
Futaba 3PK, Reciever is Futaba PCM 1024. Servos Are Futaba S9351 on steering, S9350 throttle. 1600 NiMH 6v Venom battery. I disassembled the radio tray for routine cleaning and inspection, everything passed. When I put it all back together just like it came out I turned the radio on, switched the car on and the transponder light came on but the servos did not center. I gave all the connectors a second look, everythings in the right spot and connected good. I even bypassed the switch with no luck. Both batteries are topped off. Thanks
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 10-23-2008, 09:17 PM   #2
Trader Rating: 42 (100%+)
Make sure you have the servos plugged in correctly. I know this sounds dumb, but you could have plugged the leads in wrong. I have fixed a few for people that this was the only problem. It is easy to get the leads turned around backwards into the rec. This will make them appear to be plugged in but they won't work. The black lead goes close to the outside of the rec.
Hope this helps.
mracer is offline   Reply With Quote
Old 10-23-2008, 09:42 PM   #3
Thanks for the help but Futaba uses a tongue and groove type deal on the connectors, so i know they are correct. It seems like either the servos are not getting a power supply or the radio is not transmitting or the reciever is not sending a signal to the servos.
Old 10-23-2008, 10:02 PM   #4
Sorry that didn't help. I am not familiar enough with that radio system to make anymore suggestions. I am sure tomorrow someone will be able to help you.
Old 10-23-2008, 10:24 PM   #5
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
it may be possible that the rx and tx lost there bind.. i have had that happen with spektrum in the past.
jamminnay is offline   Reply With Quote
Old 10-23-2008, 10:35 PM   #6
I dont think my radio has such a thing. Its not a 2.4 GHZ system
Old 10-23-2008, 10:36 PM   #7
jamminnay's Avatar
lol well i guess i should have read closer... i would say if our transponder light is on and the servos are not working the problem either lies with the crystals or the reciever
Old 10-23-2008, 10:39 PM   #8
Were getting closer. I didnt think of the crystals. Do they "go bad" over time? The whole deal run like a top 1 week ago, and before i tore it down.
Old 10-23-2008, 10:41 PM   #9
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
Do you have the wrong model selected in the transmitter?
Er I suppose it would still work with PCM though... But just a thought.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 10-24-2008, 08:43 AM   #10
Model selected is correct.
Old 10-24-2008, 08:59 AM   #11
Servos aren't centering or just not responding at all? If your PT is on then you know the battery is supplying power to the RX. If the servos just aren't centering, it could be several things. First question is, did you turn on the radio and power up the car before you put the servo horns back on? You have to do that first, then put the servo horns back on in the same position they were in when before.
cjtamu is offline   Reply With Quote
Old 10-24-2008, 09:14 AM   #12
Thats what I was doin. After I assembled it i turned the radio then the car on to center the servos so i could put the horns on. The servos arent centering or responding to any throttle or steering inputs.
Old 10-24-2008, 09:30 AM   #13
Take the crystals out of the receiver and transmitter and put them back in. While they're out, make sure that the crystals are on the same frequency. Are the servos getting power? B/c even if there's no radio signal they should get power, and they'll move or hum when you turn the switch on. How old is your battery? They go bad after while and it's possible the battery voltage is low too.
Old 10-24-2008, 10:11 AM   #14
Ive tried removing and reinstalling the crystals with no luck and they are of the same frequency. The battery is about 6mo old with about 1.5 gallons runtime. The servos are not making any noise when you turn the switch on. I believe there is no power reaching them.
Old 10-24-2008, 10:42 AM   #15
It's weird that the PT comes on b/c that means power is getting to the Rx. And I know with the Futaba j-plug you can only put the servos in one way so it's not likley you fried them. Try plugging the battery directly into the receiver and see what happens. If you have another receiver try it and see what happens. You can also check the battery voltage if you have a charger that also discharges. Set the discharge at 0.5 amps and voltage cutoff at 1.0 V/cell. Hit the discharge and see what it reads. I had some goofy servo issues not long ago and when I tested my battery the voltage went below 5.0 immediately. Replaced the battery and it solved the problem. The only other thing would be, did you spray the receiver with anything when you were cleaning it?
KNOX Offroad Vic The Fuhrer Australian Racing 15669 08-02-2017 11:09 PM
B.R.C.C.C (Tingalpa) hooked_on Australian Racing 6962 11-07-2011 01:58 AM
D&M Speedway Topeka Outdoor Off-Road JPMSRacing Kansas/Missouri Racing 5448 10-09-2010 09:01 AM
Ofna Buggie 1/8, racing material? (New Member) siba111 Nitro Off-Road 14 01-04-2008 12:05 AM
Jammin kill the competition on the Mexican Nats Finals !!! Tabushi Electric Off-Road 10 10-30-2006 10:45 PM
