Old 10-24-2008, 12:36 PM   #16
I tested the Battery with a Digital Multimeter, i read 6.0v. I tested the hot post for the servos in the reciever 6.0v again. What is the white wires purpoase on the servo lead? I cleaned the servos and reciever with a dry toothbrush.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 10-24-2008, 01:23 PM   #17
helivaguy's Avatar
Trader Rating: 42 (100%+)
maybe you have to reset the failsafe (i believe the pcm rx have that feature)
helivaguy is offline   Reply With Quote
Old 10-24-2008, 02:24 PM   #18
Integra's Avatar
your pack should read higher then 6.0v....u sure its charged ?
Old 10-24-2008, 02:42 PM   #19
I guess its charged. All i have is a peak charger. I topped it off before the electronics went back together, and the transmitter battery too. What should the pack voltage be fully charged? The battery is labled 6.0v.
Old 10-24-2008, 04:51 PM   #20
Integra's Avatar
fully charged it should be alot more then 6.0.........buddy's 5 cell stickman 2500 that was charged a couple days ago is at 6.6 and i was doin some Epa adjustment's so it'll be down a little from that.....so at least 6.5
Old 10-24-2008, 05:38 PM   #21
All i saw was 6.somethin and declared it good. But ive got it figured out, it was the reciever. Plugged in a a buddys reciever and put the transmitter in my radio and it worked perfect. Thanks for the help everyone.
Old 10-24-2008, 07:16 PM   #22
Just for future reference it doesn't so much matter what the static voltage is, you need to know what it's doing under load. That's whay I told you to put it on a discharger and see what happened. Gald you got it fixed.
cjtamu is offline   Reply With Quote
Old 10-24-2008, 08:17 PM   #23
Integra's Avatar
true to a point yes.
i got one of those Dynamite Sentry things that slaps a 300mah load on the battery and displays the voltage...quite the neat little unit to have track side when u question if a pack if good or not.
KNOX Offroad Vic The Fuhrer Australian Racing 15669 08-02-2017 11:09 PM
B.R.C.C.C (Tingalpa) hooked_on Australian Racing 6962 11-07-2011 01:58 AM
D&M Speedway Topeka Outdoor Off-Road JPMSRacing Kansas/Missouri Racing 5448 10-09-2010 09:01 AM
Ofna Buggie 1/8, racing material? (New Member) siba111 Nitro Off-Road 14 01-04-2008 12:05 AM
Jammin kill the competition on the Mexican Nats Finals !!! Tabushi Electric Off-Road 10 10-30-2006 10:45 PM
