Old 10-21-2008, 06:48 PM   #1
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Default explanation of effects from engine mods?
Is there anywhere that has an explanation of what each mod does for the performance of a motor?
I mean something like: silicone ramp= strictly mpg, or silicone ramp=low end torque(in reality, I have no idea what this does) I dont need stuff like 'its better flow' Do some mods cost longevity?
I dont want to go at this blindly. I need a kind of Hudy off road set up book but for engine mods
rallyebmx is offline   Reply With Quote
Old 10-21-2008, 07:33 PM   #2
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
Usually the putty type ramp in the crank is done after the crank is drilled a little deeper into the front side of the crank to lighten it up more, the putty stuff fills that hole in and "helps" the flow a bit. If you do some searches online for anything relating to a 2-stroke engine (dirtbike, snowmobile, etc...) or the exhaust system for a 2-stroke engine you will be able to learn more than any info you find that is from a r/c website.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 10-21-2008, 08:35 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
Just read this.
http://edj.net/2stroke/jennings/
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
