Old 10-21-2008, 04:49 PM   #1
jamminbce's Avatar
Default CEO powerr mods piston/sleeve v-spec
Just purchased p/s combo off amain does anyone know what reccomended head shimming with this combo
jamminbce is offline   Reply With Quote
Old 10-21-2008, 05:09 PM   #2
mugenb46's Avatar
be safe and use the 1 thin brass and 1 alum, call CEO, he should be able to tell you if you can run factory shimming or not, break it in with a P3, and if shimming needs to be less use a P6
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 10-21-2008, 05:13 PM   #3
jamminbce's Avatar
Default ceo p/s
Ive tried but i can;t get anybody on the phone but ill try that but from experience eb mod v-spec only use the 1 thin brass shim.
Old 10-21-2008, 05:24 PM   #4
mugenb46's Avatar
thats correct but not all modders cut the button and shim seat down to allow that clearence, i would send an email befor running that close squish in a new P,S just to be safe.
Brian Carey
Pro Twister Mods
615-838-5373
Old 10-21-2008, 05:25 PM   #5
mugenb46's Avatar
is the block CEO or just the P,S
Brian Carey
Pro Twister Mods
615-838-5373
Old 10-21-2008, 05:35 PM   #6
jamminbce's Avatar
Default ceo p/s
just p/s
Old 10-21-2008, 05:47 PM   #7
mugenb46's Avatar
ok, the timming may have been changed on the piston, which will allow a higher duration, so squish is important to get correct to get the bennifit of your P.S set if it was done this way. you can use calipars to measure both the stock and modded parts to see what may have or not have been done. i would shoot chris an email just to be safe.
Brian Carey
Pro Twister Mods
615-838-5373
Old 10-21-2008, 05:57 PM   #8
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
+1 I don't think Chris cuts the piston or the button.. But i would measure to be safe.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-22-2008, 01:04 AM   #9
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Pretty much same as all the posts above.
Best bet is to get ahold of Chris and he will set you up with the needed info. He is not always the easiest to get a hold of though so keep trying.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
