Old 10-21-2008, 03:38 AM   #1
mini696's Avatar
Default Setup questions. Hard packed, dusty, bumpy.
Hey guys... What kind of things can I try to make my car go through rough bits better?
What about setups on hard packed (think similar to concrete) and VERY dusty tracks?
Please try to mention, droop, shocks (spring hardness, oils, shock positioning and piston size), diff oils.
It seemed my buggy was bouncy at the rear causing poor handling at speed over bumps. Infield, slow smooth stuff was pretty good.
mini696 is offline   Reply With Quote
Old 10-21-2008, 05:40 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
If you tell us what kind of buggy you have, someone that drives that particular car can probably help. Generally however:
Softer is better for rough stuff... but only up to the point where the car isn't bottoming out. The issue you described could be too stiff (not allowing the suspension to work to keep the tires in contact) or too soft (bottoming out, and also allowing the shocks to rebound too fast. Could be that the shocks are too stiff for the springs you are using... or could be that the shocks are too soft for the springs you are using. (they have to match somewhat to work properly.)
Tell us what buggy, what shocks (piston size, fluid weight) what springs, etc. and we can probably make suggestions.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 10-21-2008, 02:23 PM   #3
mini696's Avatar
Thanks.
The car I run is a Hot Bodies D8, its setup is completely stock at the moment.
I think you might be right that it is bottoming out. The rear end has always seemed soft to me.
Springs are Grey rear (74gf), White front (81gf).
Shock oil is #400 (approx 32.5wt) both front and rear.
28mm rear ride height, 29mm front.
Diffs 5/4/1
Pistons are 6 holes/1.3mm
Old 10-21-2008, 03:23 PM   #4
slaytanic's Avatar
Trader Rating: 20 (95%+)
I like to build in a little rebound into my shocks for blownout tracks. It lets me keep a lighter setup but helps a bit with bottoming out. I only run 27.5 in the back of my 808.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
