Old 10-19-2008, 05:50 AM   #1
Default Tips on setting up brakes??
Hey guy's, can anyone give me some tips on setting up my brakes via the servo brake rods? Should i set them so there is an even amount of rod coming out of the end for both the front and rear or should i run one brake on more than the other?
I have my first race coming this weekend and while running the car in my garden i found the back locked up quite easily and spun the car around (this was on a grass surface), i had very little feel and modulation. The track i'm running on can get quite rough although it should be prepped quite well.
Any help appreciated-Thanks-Hugh
hugh_b is offline   Reply With Quote
Old 10-19-2008, 07:19 AM   #2
jrwoodchuck's Avatar
It personal preferance, most run with more rear brake, possably 90% run more rear than front. I run more front brake, simpley put, I brake early and roll threw the turn and on throttle early. You have to have a car that can turn well though. But this is my preferance. You can try different setups to see what fits your driving style.
As far as how I set it up. I will have it to ware the rear brake is not working. I then go fast down the strait and hit the brakes (no turning) and have it to ware the front tires will NOT lock up. Then I do the same with the rear. As soon as the rear lock up, I take 1/4 turn out of the rear. Then I don't touch them again. On the radio though, I will adjust my ATV's so the tires won't lock up. As the track dries out (if watered) you will need to take some of the ATV's out. But if they water the track (not muddy) you will find that you can add ATV's.
At no time do I have it to ware my tires will lock up.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 10-19-2008, 07:34 AM   #3
Gliptal's Avatar
This might be helpful, its for the Losi 8ight but should be basically the same as other manufactures.
http://www.losi.com/ProdInfo/Files/L...e_Addendum.pdf
Gliptal is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 08:22 PM
SETUP TIPS FOR TX/RX rcabj Malaysian R/C Racers 41 01-13-2008 12:55 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Any Tips for Jammin Mike.CL Electric Off-Road 13 03-15-2007 05:44 AM
