Old 10-18-2008, 03:51 PM   #1
Default GRP .21 VS Team Orion CRF .21
i am looking to get a new engine for the 2009 season. i had a 8ight with a v-spec but now i will be getting a 8ight 2.0. i was wondering what engine is better the grp with grp pipe or orion with orion pipe. thanks
HAWK498 is offline   Reply With Quote
Old 10-19-2008, 06:20 AM   #2
Shane Racer's Avatar
If you want mad power than go with the crf. It's a beast.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 10-19-2008, 09:17 AM   #3
F-1
Shane Racer, how long live the CRF motor?
F-1 is offline   Reply With Quote
Old 10-19-2008, 09:23 AM   #4
I have not had it long enough to give a true statement. I have about 3 gallons on it so far and it's still going strong.
Old 10-19-2008, 06:29 PM   #5
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
I have just under 2 gallons on my CRF,and the piston still gets sticks on the starter box when cold.. and the motor just seems to keep getting stronger.
8mm insert and 2066 orion pipe
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 10-19-2008, 06:48 PM   #6
thanks where did u get the 2066 pipe i cant find it anywhere?
Old 10-19-2008, 08:38 PM   #7
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Shane Racer , have you had any problems with the carb ? I`ve heard that Picco and Picco based engines have carb problems like when the composite gets hot it warps and there is air leaks around the metal parts . Also what plugs have you been using ? I plan to get the CRF soon but can`t find anyone that sells Orion or Picco plugs and heard many other plugs don`t fit and leak .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-20-2008, 03:41 AM   #8
I have not had that problem. I would recomend that you pull the slide out and take the sharp edges off the idle screw channel and the end of the slide just for added protection. Sometimes the carbs will stick just a little bit but after doing that they feel really smooth. I have been running a p4 in mine. I will be trying the Orion plug though.
Old 10-20-2008, 07:23 AM   #9
Default Motors
Good motors, but all of factory motors are so similiar. Modded motors seem to make cusomizations that would be difficult to reproduce in a standard manufactuing process. I have found for the money, a lower end mill modded seems to get better performance than any manufacturer motor I have seen in the past.
Relay8039 is offline   Reply With Quote
Old 10-20-2008, 07:27 AM   #10
Briguy's Avatar
You can`t compare a modded engine [lower end or higher end] to a non-modded engine . Like comparing apples to oranges .
Royal R/C & Hobby
Old 10-20-2008, 09:51 AM   #11
HarleyMf2's Avatar
i currently run the 8ight with a p7r in it but i will be sellin it and buying a 2.0 with a GRP its a good choice.
Upgrade RCID
Team Hudson
HarleyMf2 is offline   Reply With Quote
Old 10-20-2008, 02:46 PM   #12
Briguy's Avatar
Shane , are you still running Homer`s fuel ? Was thinking of making the change and after seeing the thread about it I`m going to . With the Orion engine , do I need to add or remove any shims to run 30% ?
Royal R/C & Hobby
Old 10-20-2008, 03:59 PM   #13
I am running TQ fuel now and like it a lot. There is nothing wrong with tilted at all. I just had a good oportunity and took it. TQ runs very well and would recomend it to anyone. I've run it all summer and have had no flameouts or bearing issues.You don't need to add any shims. Just hang on because it's a beast. The bottom end is very controlable and when you grab a handfull it's very fast.
Team Orion CRF WASP Clutch Set for Serpent 720 Keith_TBB Onroad Nitro Engine Zone 15 02-13-2007 02:28 AM
Brand New Team Orion Wasp .21 SB T-Maxx 2.5 Racer4Life R/C Items: For Sale/Trade 2 07-29-2006 09:43 AM
Team Orion WASP .12 CRF Engine uniquexme Nitro On-Road 2 07-27-2006 01:29 AM
WTB Team Orion Rev CRF, Oversees Dust'd R/C Items: Wanted to Buy 0 07-12-2006 12:00 PM
t-maxx parts and other hop up's look in..... bizzare6996 R/C Items: For Sale/Trade 0 08-21-2004 09:46 AM
