What pipe for a OS V spec
Oh no!!! the search nazi's are going to be all over you for this one, I wish I could help you but I can't!!!
I use an Associated 2035, its a great all around pipe and its half the price of a 2060.
I run the JP-3 and get good run times and temps in the 210 - 220 range. I've heard but not tested myself, the OS 2060 pipe allows for an almost minute gain in run times and lower or the same running temps. If you read around these boards or search you can read up on it.
Good Luck... Great engine - make sure you have a very good air filter.
I would run the pipe that EB Mods produced specifically for the Vspec. There much cheaper than the OS line of pipes hard coated and were designed for the best runtime and power. I beleive www.rccompound.com has them on there site.
Run a OS 2050 if you can find one...My next choice would be a thunder tiger 2035 nd after that would be a os 2060......2050 will give you the best run time and won`t hurt the top end....Thunder tiger acts the same as a 2050 but run time isn`t there....A 2060 will give you better top end but you will see that it effects the bottom end.........If you run a small track use the 205 or the TT 2035..If your going to run a big track try the 2060.....I have tried all 3 pipes on modded vspecs and stock vspecs
+1 O.S. 2050...PERIOD
jp-3 or os pipes
im running a jp-4 , i havent had the opportunity to run any others so i have o basis for comparison... any comments on the jp4 vs. the 2050, 2060, or jp3?
