Mugen MBX6 lipo and regulators, what are you using?
What lipo's and regulators are you guys using, I may want to go this route, any pics or other info wwould be great.
thanks, jlo
thanks, jlo
I'm using a Venom 1600mah lipo w/Protek regulator. Here's the items:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSFS6&P=7
and
http://www.amainhobbies.com/product_...ducts_id/13509
and
I was looking for something that I could get to fit inside, or some info to help modified it.
jlo
jlo
The battery I posted will fit with no modification. If you wanted something larger than 1600, this 2300 would also fit:
http://www.amainhobbies.com/product_...ducts_id/15789
and
and
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
hi guys 5.0 boy pm me and asked to send pics. but i cant get pics down enough to post. if you want picks pm me or email me and i will send them out. im using the 2000 losi lopo. and regulator. basicly i ground down the hole middle dividing lip. removed the center post also. you need to bolt and nut the 2 outer covers toegther. also grind a relief notch on the battery cover and front outer cover to bet clearance. i dont use a switch. so i ran my wires thru a hole i made in the battery long cover towards the rear. i use the futaba fast reciever also. the regulator is taped or glued unger the top front outer cover above the battery. i also add foam under and around all dead areas. hope this helps. email or pm for pics. jeremy
have some one host the pics on their photobucket or something...Much easier
i have an ofna x1 - im running the orion 1500mah lipo hump with their regulator. i have the regulator ontop of the batt. with the updated battery cover from ofna and it BARELY fits with no moddification. i mean, BARELY - i tried putting a thin piece of cloth uder the battery to keep it from scuffing ad i couldnt get the lid on.
