Old 10-16-2008, 02:47 PM   #16
TonysScrews's Avatar
I run 2S LiPo Rx packs without a regulator as well and have not had any issues. My buddy has been running them unregulated for two years in three different classes and never an issue. The servos are stupid fast and strong in 2S LiPo.
Personally I use the Hitec 5955 servos as they are rated for 7.4 volts. My buddy uses the JR 9000 servos. I know a few guys that ran the KO servos (not sure of model #), the Ace servos and Airtronics 358/359 servos on direct LiPo. I use the Nomadio React and the transceiver will handle up to 9.6 volts. The Spektrum Rx is good to 9.6 volts as well. The AMB Personal Transponder works fine too. I recently read a post on s-grid from a guy that runs a Futaba Rx on direct LiPo too but I don't believe Futaba's website says it is rated for more than 6.0 volts. But you also have to remember that a 5-cell NiMh hump pack puts out a lot more than 6.0 volts too!
I don't trust regulators/BECs. They are just another electronic component that could fail when subjected to heat/high amp draws (both of which our cars see a lot).
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 10-16-2008, 06:24 PM   #17
I have run both with & without reg with hitec & JR servos & niether showed any immediate sign of damage.I do use a reg in cars that I run lipo in simply for the higher mah rating the battery acts like it has with it.I have had 2 brands of regs take a dump on me but it could just be one in a million or the beating everything in an RC car takes I cant say for sure as I have the same regs in other cars & have no problems with ones that are a year or 2 older.
butch man is offline   Reply With Quote
Old 10-16-2008, 07:37 PM   #18
i think most of the reasons the regulators die is because they get hot and arent vented right and overheat and get damaged
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 11-10-2008, 11:06 PM   #19
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
A friend posted this link on our club forum, so after reading this post, I yanked the regulator out of my RC8T, using Nomadio Rx, Hitec 5955 and Airtronics 94359 and this kicks a$$. My battery reads 7.6 volts with no issues at all, and the servos are just nuts....lightning-fast and scary-strong.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 11-11-2008, 06:46 AM   #20
allan42r's Avatar
is the losi regulator any good?
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 11-11-2008, 07:04 AM   #21
helibrian's Avatar
Not sure if you guys are aware of it but A lot of receivers incorporate a circuit that regulates voltage to the servos. Some manufacturers market them as bec receivers, some non-bec, some don't specify either way. Of course it's not just brand specific. For example the JR RS300 does regulate voltage to about 5.5v. It's little brother the RS310 does not. So get out the multi-meter and do a quick check. If nothing else you'll have learned something about your equipment.
I'm betting quite a few people are using regulators for no reason.
That'll be 2¢ please.
helibrian is offline   Reply With Quote
Old 11-11-2008, 08:48 AM   #22
Trader Rating: 42 (100%+)
If you choose not to get a regulator with a low voltage cutoff, one thing to remember, someone may have already mentioned this, is be sure to keep your lipos charged. Some regulators limit the high voltage but will not keep the lipos from falling below a certain voltage. Thus, if you run too long before charging and your voltage falls below 6 volts your lipo pack could be done. I have seen two instances when this happened. By the time the servos get sluggish there is a chance it is too late. So, if you choose to run lipos and a reg., keep the batteries charged.
mracer is offline   Reply With Quote
Old 11-11-2008, 08:51 AM   #23
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
most ppl cant handle a servo unregulated it just to fast.
i dont run one my self just another thing to cost me a race.
i like the speed it give me and the power
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 11-11-2008, 09:25 AM   #24
Trader Rating: 96 (100%+)
I ran my servos without any regulator simply because there was no room in the rx box for it, and never had any issues. I only ran a couple races like that so I can't comment on the long term effects, but I dont think there would be any problems regardless.
K.Copeland is offline   Reply With Quote
Old 11-11-2008, 09:51 AM   #25
My React radio displays my Rx battery voltage, and I set the failsafe for the Rx battery to go on at 6.4 volts to be on the safe side. My losi lipo pack is a 2000 mah pack, it reads 7.6 volts on my radio. Once it drops to 6.4, my radio will kick the brakes in, and I know it's time to quit. I LOVE THIS MOD! The extra speed and power is fantastic!
The Losi regulator is ok in some scenarios. I had it in my LST2racer but when I changed my steering servos to two Hitec 7955, I wasn't getting enough power to my electronics, and my failsafe was kicking in within minutes of being on the track-VERY annoying. My race partner runs one with his Airtronics servos, and has no problem, but he's taking it out after seeing my current setup.
Old 11-11-2008, 09:53 AM   #26
JayL's Avatar
the regulator also keeps the servo's consistent! I think this is the best thing, near the end of the hour your servo does the same thing it did at min 1
JayL is offline   Reply With Quote
Old 11-11-2008, 12:27 PM   #27
That's not a huge concern for me with LiPo. I ran my truck for 4 hours straight the last time I was at the track...it would run out of fuel, I'd run over and fill it, start it and run it...for 4 hours straight,maybe stopping twice for 15 minutes and I never noticed any drop in performance the whole time. At a race, I would never get that much track time, so I'm not worried about that.
Old 11-11-2008, 01:22 PM   #28
I have been running lipo receiver packs for a while now, i tried going back to nimh, and its not the same lol Plus my batteries lasted 2 years....they were 28 dollars each! I use a regulator though...as it will allow your batteries to last longer, without a regulator, all your volts dump right in...i would get around 35 minutes of runtime without a regulator on my 1000 cell, regulated, i got nearly an hour and a half! but you can run it either way depending on your servo, as Tony stated, i use Hitec servos with zero issues. Servos are awesome.
I remember i had to replace my receiver batteries every 2 months or so, depends how often i had to use them...LIPO saves cash in the long run for sure! just have to properly care for them, and they will last a long time..
forgot to add, but i usually wrap the LIPO battery with some heat shrink as added protection right when i get the battery, and i pad it with some good foam...and charging has never been so easy...its simply great.
I got my starter box and my KO radio strapped with LIPO...best thing ever.
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
much more power supply,triton 2 charger, equinox lipo balancer twistedone R/C Items: For Sale/Trade 5 03-05-2008 10:14 PM
RC18T with Mamba (Lipo or Nimh?) cj.g Malaysian R/C Racers 5 07-27-2007 09:24 PM
DC Motor Sports Discussion Thread: Curtis Schlaht Team and Company Discussions 2010 11-28-2006 10:42 PM
LiPo vs NiMh…. Hayden Electric On-Road 3 06-10-2006 08:27 AM
