Old 02-16-2010, 05:16 PM   #211
Trader Rating: 61 (100%+)
Originally Posted by mikenix View Post
I found the best technique for installation on Losi is simply put a point on your pins then literally drive them in like a nail...
+1 on all losi style pins ..i sharpen em like a pencil for sure
i will be running the answer flag this week end at the 2nd annual bamajama ...got everything ready to rock ..wish me luck ..
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 02-16-2010, 05:40 PM   #212
mikenix's Avatar
Trader Rating: 21 (100%+)
Originally Posted by dishsoap View Post
You know that makes sense. The hardest part is the first hole passing the first part of the spring. Once you get through that it was easy.
Did you use a hammer.
Nope just the nearest hex driver with a little size to it.
www.answer-rcusa.com
Contact me for details.....
When you sling mud, you only loose ground. - Fat Albert
mikenix is offline   Reply With Quote
Old 02-16-2010, 07:21 PM   #213
pballer2777's Avatar
Trader Rating: 27 (100%+)
i found the easiest way is to put the flywheel in a vise. put the pin in tilmit hits the spring, then push the shoe down with a flat screwdriver then push the pin in the rest of the way.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 02-16-2010, 07:53 PM   #214
THE PHILLY JYNX's Avatar
[QUOTE=mikenix;7015954]Nope just the nearest hex driver with a little size to it.[/QUOTE
Like Mike suggests,Round the pin(were the end and length make a 90 DEG angle) off slightly.Put the pin through the flywheel,shoe and spring.Take your thumb and push down on the clutch shoe,lining the pin up with the back hole of the fly wheel.Put the head of the pin against a solid vertical service and push the pin in to the threads.Do all 4,dip the tip(just the very end) of a thin regular screwdriver in a drop of blue loctite and touch all 4 sets of threads on the pins.Screw the pins in just snug and back out just a hair and your GOOOOD to go.Also you may want to take a little length of the end of the springs that go into the clutch shoes
BuKu Performance Products
S&W Fuel
Team Sweep Racing Tires
AbsoluteHobbyz VP-PRO
THE PHILLY JYNX is offline   Reply With Quote
Old 02-16-2010, 09:11 PM   #215
dishsoap's Avatar
[QUOTE=THE PHILLY JYNX;7016731]
I thought blue loctite was never to be used on the pins
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 02-16-2010, 09:16 PM   #216
mikenix's Avatar
[QUOTE=dishsoap;7017155]
I've never seen a pin actually backout but I know many do this but I don't. You just had to hammer the pin in can't image it will back out. This probably is part of the cause of losi pins stripping like mad or our pins snapping the head off.
Old 02-16-2010, 09:43 PM   #217
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
i would like to thank mike for all his help last year and i am looking forward to 2010 with him and the rest of the team.
hows that one look mike
i bought one the first set of motor bearing and i will say there still alive in perfect shape and been in to motors mike i gone need another set soon lol
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 02-22-2010, 02:50 PM   #218
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Got to run the new Silver shoes in my Truggy this weekend with a .28. They grab strong and consistent all weekend. Little to no signs of wear. Used 1.0 springs.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 02-22-2010, 03:45 PM   #219
RJNicholson's Avatar
Finally got the Losi shoes installed on a steel flywheel.
I didn't have a binding issue at all on the steel flywheel and they fit perfect.
I can't wait to see how they perform. I will post some feed back once I can finally get some good run time on the motor. Still really cold and up and down with the weather in Dallas Texas.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 02-23-2010, 09:48 AM   #220
Shoaf85's Avatar
Trader Rating: 19 (100%+)
My order from Answer is on the way. Lots of interest locally in this product. Curious to see what the popular items are so I can keep them stocked up?
Team AE all the way...
FASTLANE GRAPHIX !!!!!!!!
Shoaf85 is offline   Reply With Quote
Old 02-23-2010, 05:05 PM   #221
mikenix's Avatar
Bob,
Those are prototype shoes from Pete in the UK, I think they will be black in the end. Perhaps we can keep them silver just to show they're different.
I also used the Losi steel flywheel at motorama this weekend fitment seemed fine as well.
Here are the top 20 US products. Thanks for the order!
Answer-RC 3 Shoe Clutch High Bite Low Wear Clutch w 3pks Springs 490
Answer-RC Losi 4 Shoe High Bite Low Wear Clutch w 3pks Springs 328
5*10*4 "SP" Clutch Bell Bearings 10pk Red Seal / Metal Shield 254
Answer-RC RC8 3 Shoe Clutch High Bite Low Wear Clutch w 3pks sp 150
8*16*5 "SP" Wheel / Diff Bearings 10pk Red Seal / Metal Shield 138
Answer-RC Losi 8ight B / T Shock Spring Holders Long - Red 126
ANSWER-RC TEAM LOSI 8IGHT & 8T "SP" CLUTCH BEARINGS - 4 PAIRS 114
Answer-RC Losi 8ight Ridge Cut HQ Foams 10pk 111
Answer-RC Brake Release Spring Set x 12pcs 98
Answer-RC Exhaust Gasket Set x2 pcs Shaped .21+ Black 90
Answer-RC Team Losi 8B 8T 1.0 2.0 13t Clutch Bell w. 2 x Bearing 89
Answer-RC 13t 1/8th clutch bell w. 2 x Bearings 86
Answer-RC Exhaust Rebuild Set BLACK 86
Answer-RC Losi 8ight B / T Flywheel Pins Flat Head 80
8x14 Bearings XRAY 808 Losi 8B 8T HB D8 10pk 76
Answer-RC Losi 8ight B / T Shock Spring Holders Long - BLACK 75
Answer-RC 3 Shoe Carbon Composite Clutch w 3pks Springs 71
5*13*4 "SP" Losi Rear Clutch Bearings 10pk Red Seal / Metal Sh 65
7*19*6 "SP" Front Engine Bearing Double Red seal .21 - .32 56
Answer-RC Team Losi 8B / 8T Full SP Bearing Set 24pc 51
Old 02-23-2010, 05:09 PM   #222
Shoaf85's Avatar
Thanks for the info Mike I will be in touch again soon!
Old 02-23-2010, 05:11 PM   #223
losi_racer's Avatar
Trader Rating: 25 (100%+)
wow you guys have issues with clutches lol. i dont do anything with the pins. Ive done enough clutches i can do the whole thing(disassemble and reassembly) in 5 min. guess its a feel thing, btw NEVER use loctite. ive never seen a pin loose, if you say you have you did something wrong. those pins strip very easy, i have hudy tools and ive even stripped 1-2 since getting them. you just cant over tighten them.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-23-2010, 10:14 PM   #224
dishsoap's Avatar
Answer shoes are the BOMB!!!!!!!!!!!!!
I ran them this past weekend at the Dirt Nitro Challenge. On main day the track was really bad for the first few races. Two pounds of mud on the car when coming off the track.
The shoes held up extremely well with no wear. Last time I ran in those conditions with non answer shoes they filed down to a pulp.
Nice job Mike!!!!!!!!!!!!!!!!!
Old 02-24-2010, 09:08 AM   #225
I'd have to agree on the Answer Shoes and bearings being top notch. I've been running them for about a year now and have gotten great life out of them. I also had gone to the Nitro Challenge this last week and I hated the first couple day's as every time I turned around something went wrong, lost a steering servo, New Voltage regulator, Reciever, busted off the whole rear wing mount (Becouse I'm Blind and can't see at night) then some problems with my 1/10 electrics but in the end the ANSWER Products carried my almost double weighted Caster Buggy through the mud and I got a bump up from the G to the F main but only had time to re-fuel then get checked in for the next main. With every crack and crevis packed with mudd and the suspension barely moving the clutch was still able to grab the bell and throw my buggy up and across all of the jumps. They just need a little cleaning up and a new set of 1.1 springs and bearings and the plus 4 will be ready to rock again.
A special Thank You to Answer-RC USA, Caster Racing USA, GFD Racing, Prime Racing Fuels, HC&M Hobbies in Sparks Nv. and My Wife for letting do what I do.
Dave and Becki is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Losi Clutch Bell Bearing problems. l3asher Nitro Off-Road 36 05-16-2010 09:31 AM
