Old 05-11-2009, 11:52 AM   #151
mikenix's Avatar
Trader Rating: 21 (100%+)
Originally Posted by roadracer43 View Post
Which clutch and flywheel do I need? Better yet, what all do I need to change over to this 3 shoe clutch ?
This one has everything including bell
http://answer-rcusa.com/zencart/inde...products_id=90
This one has everything minus bell, if you want to use the Losi bell.
http://answer-rcusa.com/zencart/inde...products_id=91
I would also recommend getting some alum shoes, if you want plenty of clutch snap.
http://answer-rcusa.com/zencart/inde...&products_id=4
www.answer-rcusa.com
Contact me for details.....
When you sling mud, you only loose ground. - Fat Albert
mikenix is offline   Reply With Quote
Old 05-11-2009, 12:02 PM   #152
thanks for the info. Will this set up make a big difference in performance or is it more for saving a little money and durability ?
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-11-2009, 12:04 PM   #153
also, can I run this clutch set up with the losi quick change engine mounts ?
Old 05-11-2009, 12:10 PM   #154
mikenix's Avatar
thanks for the info. Will this set up make a big difference in performance or is it more for saving a little money and durability?
Can't make any claim on performance or durability. If you own the Losi setup and don't have any three shoe stuff you're probably not saving any money.
I know one of the quick change mounts (not sure which brand) has additional mounting holes. I know that these holes can be used instead of shimming the collet to get the clutch extended out.
Old 05-11-2009, 12:33 PM   #155
Trader Rating: 32 (100%+)
any one know/try this on the O'donnell z01 buggy?
devilchrist is offline   Reply With Quote
Old 05-11-2009, 08:07 PM   #156
Akhor's Avatar
Originally Posted by mikenix View Post
Hopefully 2 weeks out. Sorry for the delay we had an unexpected run on the Losi shoes and both me and the UK are completely out.
Can you PM me when they are back in stock?
Thanks!
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-12-2009, 07:30 AM   #157
mikenix's Avatar
Are you referring to the use of the Answer-RC clutch on the z01b? I believe it uses the standard three shoe design, but I'm not aware of anyone using them on that buggy. I would love to some feedback, but I imagine the results will be similar as other buggys.
Akhor
I will PM when the Losi stuff lands. Thanks much!
Old 05-28-2009, 07:57 PM   #158
mikenix's Avatar
All Losi clutch parts new and now in stock
http://answer-rcusa.com/zencart/inde...ex&cPath=13_18
Losi shock spring holders
http://answer-rcusa.com/zencart/inde...index&cPath=19
Thanks!
Old 05-28-2009, 08:12 PM   #159
Frank L's Avatar
Trader Rating: 148 (100%+)
Mike I tried to run your clutch shoes on my 8T 2.0 and the shoe pins seemed to not let the shoe to move freely like it was binding or did not return back to its normal resting position. Is this a problem that usually occurs or did do some user error?
Old 05-28-2009, 08:13 PM   #160
Frank L's Avatar
The king headz quick change engine mount has the regular and losi mounting options.
Old 05-28-2009, 08:28 PM   #161
mikenix's Avatar
100% not your fault Frank. Fit the shoes without springs first to insure proper clearance with the clutch pin threads coming through the top of the flywheel. Losi has several different versions of the flywheel and on some the top is thinner, so the threads might catch or bind the shoe. If you find the thread from the pin catches the shoe just use a drill bit to relive the area a bit more.
Old 05-29-2009, 04:53 AM   #162
mfrosty's Avatar
Trader Rating: 14 (89%+)
Bump for the best deal on clutch shoes around!
Mike, can't wait till MRH starts carrying these. They're going to sell like hotcakes.
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 05-29-2009, 06:24 AM   #163
JUD
JUD's Avatar
+2!!! BEST CLUTCH AND SHOE COMBO PERIOD!!!
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 05-29-2009, 06:31 AM   #164
jpz_67's Avatar
Trader Rating: 56 (100%+)
I have been running the complete answer clutch kit on my mbx6 buggy for about a week now and have managed to put half a gallon of fuel through it. I am going to put a full gallon through the clutch and further report my findings but so far I am impressed. The shoes show very little wear and grab very good. The clutch bell shows to be wearing good also. I was very happy that the spacing of the clutch aligned perfectly on my buggy. No major shimming was required and the clutch bell and spur gear make full contact. So far a great clutch.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 05-29-2009, 06:56 AM   #165
mfrosty's Avatar
The set I'm running now has almost 2 gallons on them and still have another race day left easy. Of course .9 springs help a lot with shoe wear.
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Losi Clutch Bell Bearing problems. l3asher Nitro Off-Road 36 05-16-2010 09:31 AM
