Old 10-14-2008, 09:22 PM   #1
Default servo???
Just curious again. My truggy seems to have less than par braking. Maybe its me, but my throttle servo doesnt exactly put out on the brake side. ITs a Losi 8t btw, i was wondering if i should bump up to a high torque servo there too. My steering is a JR 9100 series, bad Jose, but the throttle just a 30 dollar cheapy, any suggestions?
motoclay is offline   Reply With Quote
Old 10-14-2008, 09:33 PM   #2
Fear's Avatar
Send a message via AIM to Fear
Z9100S. Quicker than you'll ever need, and 180oz of torque to boot. More than enough for any throttle servo. I use one, and will buy the same when mine shits the bed.
Robitronic Avid
MambaMax 7700kV, LiPo, JR Z9100S
Associated RC8
RB S7, JR Z9100S/Z9100T(nuked, at JR for repair)/Futaba BLS-351
Futaba 4PK
Fear is offline   Reply With Quote
Old 10-15-2008, 05:23 AM   #3
lowey79's Avatar
+1 Awesome thottle/brake servo!
lowey79 is offline   Reply With Quote
Old 10-15-2008, 05:41 AM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
See signature. Or just run the bad momma on both...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 10-15-2008, 08:30 AM   #5
haha, adding to my order on a main lol
Old 10-15-2008, 09:12 AM   #6
Akhor's Avatar
I also use this one, and it has held up no problems.
Akhor is offline   Reply With Quote
Old 10-15-2008, 02:01 PM   #7
NeoNot's Avatar
What about the new Vortex servos???
Any seen or heard any additional information about these other than the press release on them???
If the specs are correct on the press release the Vortex servos have to be considered on anyones list as long as the price is competitive.
ORI68000 Vortex Digital Servo VDS-2015 (20kg/0.15sec) = 277.5oz/in
ORI68001 Vortex Digital Servo VDS-1007 (10kg/0.07sec) = 138.9oz/in
ORI68002 Vortex Digital Servo VDS-1409 (14kg/0.09sec) = 194.4oz/in
NeoNot is offline   Reply With Quote
Old 10-15-2008, 02:41 PM   #8
Trader Rating: 36 (100%+)
...another nod for the 9100S
Also, I've had my fair share of "cheapie" T/B servos. While not quite as nice as what I am running now, they can be very effective. One thing to always look at is your brake discs. Take apart the center diff, remove the discs, and clean em up. You could also use very fine grit sandpaper. I guarantee if you do this regularly, you'll see a big difference with whatever T/B servo you use.
NitroOB4You is offline   Reply With Quote
Old 10-15-2008, 03:19 PM   #9
I believe he said the 9100 was on his steering and he is using a cheapy on the throttle/brake side.
Anyways without knowing what your "cheapy" servo is its hard to give advice but I would start by checking your linkage and endpoints. If all that is good might be time for a new servo. If you wanna get the baddest out there get a 8711 jr servo(403 oz of torque) but a cheaper servo should do the job just fine.
blowpopracer is offline   Reply With Quote
Old 10-15-2008, 04:35 PM   #10
Fear's Avatar
He is using the 9100T for steering.
No buggy needs 400oz of torque to apply adequate braking power.
Robitronic Avid
Associated RC8
Futaba 4PK
Old 10-15-2008, 06:24 PM   #11
Ok first Learn to read!!!!! His post says he uses the 9100 on steering but wants to know about the throttle brake servo cause he only uses a cheapy. He did not say he has the 9100 on the T/B.
Second... I stated that the 8711 is way overkill however if he wanted the baddest out there that was the one.
Please read my posts before commenting and making yourself look like a fool!
Old 10-15-2008, 10:58 PM   #12
Fear's Avatar
I lol'd.
Robitronic Avid
Associated RC8
Futaba 4PK
Old 10-16-2008, 02:07 PM   #13
FatBoyObese's Avatar
A higher power servo would help but my advice is to check your disc/pad setup as this is crucial to setting up the 8ight Ts brakes...if the gap between the pad and disc is too great then you will be at the end of the servos throw, or at the brakes caliper arms limit, before max braking is achieved, also ensure that your EPA's are setup correctly as this also can be a cause of below par braking.
I've been using my cheapo backup servo on my 8ight T after my ACE DS1015 gave up and to be honest the braking is still strong enough to lock the wheels up on the loose surfaces and do stoppies on tarmac
My impatience IS my WEAKNESS
Losi 8ight T. Hitec HSR5995tg. ACE DS1015. Fioroni OT Sliding clutch. Spektrum DX 2.0
Mach 427..Ported Jammin JP2 zorst
FatBoyObese is offline   Reply With Quote
JR s9100t servo for sale, excellent condition mini-dub R/C Items: For Sale/Trade 9 08-14-2009 01:02 AM
starter box,tools, servo & lipo charger fstnv1 R/C Items: For Sale/Trade 17 08-13-2009 11:15 AM
Advantage of .10 over .15 servo speeds ikevanbrauer Nitro Off-Road 42 08-12-2009 12:57 PM
