Old 10-15-2008, 10:09 PM   #16
Turbine_au's Avatar
I'd charge the igniter at 0.2A. I have a 7hr lead acid as well that I set the start rate at 2A, however, the charge rate will drop as the lead acid gets charged.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 10-15-2008, 10:20 PM   #17
Trader Rating: 95 (99%+)
For your glow ignitor it depends on how much you use it. If you only race on the weekends then to get the most life out of it you would be best served to completely discharge it after finished with it for the weekend and leave it sitting dead until the day before you need it and charge it back up the day before you need it. If you use it often throughout the week you should get a couple of weeks on a charge. Before charging back up you should discharge it completely before charging back up. You can then charge back up immediately or wait till you need it again.
Either way constantly topping off the nicad battery will create a memory in the battery and greatly shorten the charged life of the unit.
I always charge mine at 1.5 amp but that rate or anything under will be fine.
As for the 12 volt. They are maintenance free with the exception that you do not want to let one of them sit around dead. When the sit dead they have a tendancy to lose the ability to take a charge. They are fine if you run them dead and then charge them right back up but if they go dead the longer you let it sit without a charge in it the greater the chance it won't take a charge. At the end of nitro season I always completely charge mine up before storing them.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 10-15-2008, 11:01 PM   #18
xyzyx00's Avatar
what rate should i discharge the ignitor battery and should that go down to
0v?
and then dont bother discharging the leadacid, just charge as needed and charge before storage?
xyzyx00 is offline   Reply With Quote
Old 10-16-2008, 05:41 AM   #19
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
You want to discharge a Nicad to 0V .
Don`t discharge the leadacid , just charge when needed .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-16-2008, 07:48 AM   #20
Integra's Avatar
How do u discharge to 0V ?
Old 10-16-2008, 08:10 AM   #21
Briguy's Avatar
With my Ice .
Royal R/C & Hobby
Old 10-16-2008, 08:27 AM   #22
Integra's Avatar
Originally Posted by Briguy View Post
With my Ice .
ive always been told to discharge to .8v - 1.1v pending on the cell and what your trying to do.
Old 10-16-2008, 08:30 AM   #23
Briguy's Avatar
That is for Nimh , not Nicad . He stated he has a Nicad .
For Nicads you store them totally discharged and discharge them to 0 when cycling .
Royal R/C & Hobby
Old 10-16-2008, 01:22 PM   #24
I cant believe it but I am with Integra here, discharging a NiCd to 0V is not needed, .9V for NiMh and NiCd... going to 0V is risky and uneeded especially for a glow ignitor.
FactoryTeam08 is offline   Reply With Quote
Old 10-16-2008, 03:09 PM   #25
Briguy's Avatar
I guess neither of you raced before nimh batts came out .
Royal R/C & Hobby
Old 10-16-2008, 03:33 PM   #26
1200 SCR Sanyo's, my first battery, best batt of all time the 2400 NiCD, but we are talking about a glow ignitor here .9V is all u need 0v not needed.
Old 10-16-2008, 03:47 PM   #27
Briguy's Avatar
Nicads build up memory if not discharged all the way , no matter is 6 cell pack or one cell .
Royal R/C & Hobby
Old 10-16-2008, 05:56 PM   #28
0V not needed for a igniter but I was around when every racer dead shorted their nicads with a copper bracelet & I'm pretty sure it was trinity that sold the dead short rings & most of the racers in the world used them. I would make real sure the batt doesnt say nimh on it as many use those for ignitors now. Either way a big mah ignitor will need to be replaced for a worn tip before the cell sees noticable damage if you take even reasonable care of it.
butch man is offline   Reply With Quote
Old 10-16-2008, 08:37 PM   #29
xyzyx00's Avatar
the battery is a NiCad- i attempted to discharge it to .8v at .2A ... the charger said it was done but when i put my meter on the battery afterwards it still read 1.16V - am i not understanding something?
Old 10-16-2008, 08:40 PM   #30
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
no need to discharge to .o
jamminnay is offline   Reply With Quote
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
1s Lipo Battery Options?? pejota Electric On-Road 139 03-03-2010 02:38 PM
New lipo competiter "Cheapest & Fastest" R.Fenstermacher Electric Off-Road 69 09-01-2009 07:52 PM
Lipo Heat during a race nwilcox88 Electric Off-Road 21 08-15-2009 10:23 AM
Transmitter batteries INFERN0 Electric On-Road 7 10-27-2004 12:24 PM
