Old 10-16-2008, 07:25 PM   #61
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
well if all three of your rec went into failsafe in the same week did you ever think it could be our module that is screwed up?
jamminnay is offline   Reply With Quote
Old 10-16-2008, 07:28 PM   #62
Toiffel's Avatar
Trader Rating: 52 (100%+)
true, going to send module and receivers to Futaba, maybe they will be bale to figure it out.
Toiffel is offline   Reply With Quote
Old 10-16-2008, 07:36 PM   #63
jamminnay's Avatar
i am pretty sure.. the guy that repairs stuff for futaba is top notch... i race with him
Old 10-16-2008, 07:51 PM   #64
DogboneS's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Toiffel View Post
how do you disable the failsafe in PPM mode?? I checked and it's not even appear as an option in the menu.....
I run HRS mode with Futaba digital servos. Do you prefer PPM?
DogboneS is offline   Reply With Quote
Old 10-16-2008, 07:54 PM   #65
jamminnay's Avatar
i have always ran hrs mode myself
Old 10-16-2008, 08:09 PM   #66
Toiffel's Avatar
just one last thought, if it is the module, why when I bypass the on/off switch and the regulator the system doesn't go into to failsafe???
Tried the fm module, and no problem at all.
Old 10-16-2008, 08:43 PM   #67
jamminnay's Avatar
maybe it tricks the receiver in to things are good.. i really do not know. sounds like a good question for futaba,
Old 10-17-2008, 03:50 PM   #68
JayL's Avatar
according to the manual: you can only use failsafe in PCM or HRS
so if you are in PPM then you have no failsafe activation possible
JayL is offline   Reply With Quote
Old 10-17-2008, 10:52 PM   #69
Tin
The regulator, maybe but the switch, I dont think that has anything to do with it. Unless your switch is bad and is not connecting well. Other words, badd connection, not enough juice flowing. I was talking to my hobby rep and he asked what model servos are we using. He said sometimes certain servos will drain a lot amperage, therefore it can heat up the servos. Then on some servos , without the use of a regulator, the servos cant take all the juice so most of the power will get backed up into the receiver and can also heat it up.
Tin
Tin is offline   Reply With Quote
Old 10-18-2008, 07:07 PM   #70
jamminnay's Avatar
well i sold the 3pk... 4pk here i come!!!
Old 10-19-2008, 12:15 AM   #71
Tin
Nice, the 4pk is a lot lighter and it feels more balanced on the hand. Dont know weather I should seel my 3pk or keep it as a backup radio.
Old 10-22-2008, 06:37 AM   #72
Toiffel's Avatar
Default PROBLEM SOLVED......
Well who would think that three different Losi Lipo packs would go bad, two mine and one of my friends were bad, everytime we used them they would go into failsafe (except if we bypassed the regulator or we used FM module and receiver) tried a different Lipo HT or something like that no failsafe.... So I'm back to NIMH and no problems at all, no more lipo's for me, except in my transmitter and starter boxes.....
Thanks for all the help!!
Old 10-22-2008, 09:35 AM   #73
JayL's Avatar
yeah!
yep one guy at my onroad nitro track had multiple bad losi batt's and reg's
makes me happy I went with 1700 nimh
Old 10-22-2008, 01:06 PM   #74
Tin
Now we just have to find out why the lipos are causing this.
Old 10-22-2008, 01:18 PM   #75
cnk
Might not be the LiPo, could be the regulator since everything seemed to work find when it was removed.
cnk is offline   Reply With Quote
FM or 2.4 GHz????? vw addict Nitro Off-Road 43 06-18-2008 08:23 PM
Problem with brand new 3PKS/FASST chris3g Nitro On-Road 22 02-28-2008 10:40 PM
