Old 10-15-2008, 01:41 PM   #46
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
so i wonder if the 604 is better then the 603? im wanting to run lipos in a bad way but scared to with the past history of futaba... Ive thought about switching to KOPROPO but dont know if ill like there radios. Im pretty use to the futaba
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 10-15-2008, 03:32 PM   #47
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i had one problem with the fasst system the whole time i ran it.... not even close to the number of problems that i had with the spektrum stuff
jamminnay is offline   Reply With Quote
Old 10-15-2008, 06:07 PM   #48
Toiffel's Avatar
Trader Rating: 52 (100%+)
ok this is driving me crazy, maybe in my frustration I'm missing something, please let me know:
So far i have done the following
With this receiver 603FS (this is the one the problem started with) I have replaced servos, switch, regulator, lipo battery, NIMH battery and it still goes into failsafe
Swapped receiver with a 603FF replaced all of the above and still failsafes.
When I eliminated on/off switch and regulator it works perfect with both receivers and original or new servos.
That's in my losi truggy, in my buggy running the same setup not the same equipment (LIPO, On/Off switch, losi regulator and 603FS receiver) tried and I tried and does not go into failsafe, confirming that the radio is working fine.
How safe is it to run without the regulator???? What did I miss????
Toiffel is offline   Reply With Quote
Old 10-15-2008, 07:14 PM   #49
jamminnay's Avatar
i believe if you run without the regulator your servos will get the full power from your lipo which is not a good thing
Old 10-15-2008, 11:01 PM   #50
Fear's Avatar
Send a message via AIM to Fear
Originally Posted by carlosm View Post
Too bad Futaba is selling lemons and doesn't want to make it right!
All I can say is ....Glad i have a Spektrum DX3R!
My 4PK works great, zero issues. More than I can say for both my DX3.0 and DX3R that were bad out-of-the-box. Every company has issues, and instead of hearing all the good things on the internet, all you hear is the bad.
Robitronic Avid
MambaMax 7700kV, LiPo, JR Z9100S
Associated RC8
RB S7, JR Z9100S/Z9100T(nuked, at JR for repair)/Futaba BLS-351
Futaba 4PK
Fear is offline   Reply With Quote
Old 10-16-2008, 06:20 PM   #51
Toiffel's Avatar
this is complete BS now my 3rd receiver 603fs just went into failsafe, what the hell is going on!!!!!!!!!!!!
Old 10-16-2008, 06:32 PM   #52
Tin
How long do you use it before it goes into failsafe? Have you tried reading the temp on the receiver?
Tin
Tin is offline   Reply With Quote
Old 10-16-2008, 06:33 PM   #53
Tin
Maybe Futaba are going to have to start retrofitting heat sinks on to them receivers.
Old 10-16-2008, 06:33 PM   #54
Toiffel's Avatar
3 seconds, I've had it with this system......
Old 10-16-2008, 06:36 PM   #55
Tin
WOw, 3 seconds. Thats like just turning it on and it dumps on you. damn.
Old 10-16-2008, 06:40 PM   #56
DogboneS's Avatar
Trader Rating: 20 (100%+)
Only time I had problems with my FASST system, is when I set a failsafe point in the models memory at the transmitter. Disable it and the car obviously never goes into failsafe. Did you set a failsafe point?
DogboneS is offline   Reply With Quote
Old 10-16-2008, 06:53 PM   #57
Toiffel's Avatar
how do you disable the failsafe in PPM mode?? I checked and it's not even appear as an option in the menu.....
Old 10-16-2008, 06:54 PM   #58
D8
D8's Avatar
here is the solution... THROW THE POS AWAY!!!
D8 is offline   Reply With Quote
Old 10-16-2008, 06:55 PM   #59
Toiffel's Avatar
fasst sytem with all three receivers going on the shelf, using my trusty 75mhz module and channel 90. screw this, I'm not dealing with it anymore, it never let me down until today, all three of them in less then a week......
Old 10-16-2008, 06:57 PM   #60
Toiffel's Avatar
someone mentioned an xtreme link system http://www.xtremepowersystems.net/xtremelink.php or something like that, any feedback on it??
FM or 2.4 GHz????? vw addict Nitro Off-Road 43 06-18-2008 08:23 PM
Problem with brand new 3PKS/FASST chris3g Nitro On-Road 22 02-28-2008 10:40 PM
