Old 10-13-2008, 07:15 AM   #1
Toiffel's Avatar
Trader Rating: 52 (100%+)
Default Steering Servo acting weird!!!!!
I have a Airtronics 959 in my truggy, and have noticed while I accelerate or hold the throttle wide open, the steering servo moves left to right, not a lot but it def. moves, is this a sign of the throttle going bad?? or something else?? I've had the servo for maybe 2 years.....
Toiffel is offline   Reply With Quote
Old 10-13-2008, 07:45 AM   #2
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Airtronics doesn`t have a 959 servo . All their servos start with 94 and are six characters long .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-13-2008, 07:56 AM   #3
boostfiend's Avatar
Sounds like a faulty ground or receiver error.
boostfiend is offline   Reply With Quote
Old 10-13-2008, 07:58 AM   #4
helibrian's Avatar
Well, the possibilities are endless.
Here's a link to some info that may point you in the right direction.
http://www.rchobbies.org/cars_stop-radio-glitching.htm
Good luck and let us know how it turns out.
helibrian is offline   Reply With Quote
Old 10-13-2008, 08:02 AM   #5
Briguy's Avatar
Sometimes this happens when the insulation is worn on a wire and is toughing metal , or touching another servo wire , or antenna wire . But it could be dozens of small things . If you have a spare steering servo try it and see if the same happens or not .
Royal R/C & Hobby
Old 10-13-2008, 08:04 AM   #6
Toiffel's Avatar
I meant 359
Old 10-13-2008, 08:13 AM   #7
Briguy's Avatar
Do you mean 94359Z ?
Check the wires and try a different servo .
Royal R/C & Hobby
Old 10-13-2008, 08:20 AM   #8
Toiffel's Avatar
wow, yes we are talking about
Airtronics 94359Z
Weight 2.18 oz
Dimensions 1.54x0.79x1.47
Torque @ 4.8V 160inch/oz @ 6v 200inch/oz
Speed @ 4.8V .13 Sec @ 6v .10 sec
Coreless motor and 2 ball bearings
Not to be confused with ??????????
C'mon stop being soo complicated.......
Old 10-13-2008, 08:23 AM   #9
Briguy's Avatar
Airtronics has older models that have your 359 number in it . Can`t do much help unless we know which servo you have . complicated ? No .
Royal R/C & Hobby
Old 10-13-2008, 08:24 AM   #10
helibrian's Avatar
Lotta sticklers for detail here. Maybe it's a good thing.
Just check out that link. You should be able to track it down.
Old 10-13-2008, 08:50 AM   #11
moeman's Avatar
Trader Rating: 26 (100%+)
I've had bad switches cause weird things to happen to servos. Everything from glitches to an occasional runaway...
moeman is offline   Reply With Quote
Old 10-13-2008, 08:52 AM   #12
Toiffel's Avatar
tnx Heliman I''l do that and will switch servos too!!!
Old 10-13-2008, 08:53 AM   #13
Toiffel's Avatar
yeah I'll probably bypass on/off switch make sure that's not the cause. I just thought that my
Airtronics 94359Z
Weight 2.18 oz
was getting old and tired.
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Quick Ace servo question D Hunt 3 Nitro Off-Road 28 05-06-2008 03:10 AM
MAKE AS MANY PAGES AS YOU CAN HERE TAMIYAMANUK Chat Lounge 19 03-22-2006 06:49 PM
Ask Team Butter HEWITT Florida Racing 102 11-19-2004 02:24 PM
