Old 10-12-2008, 09:52 PM   #1
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Default What servo for 1/8th scale buggy
Hi,
Which servo should i go for my mbx6 for steering. I want something blazing fast, yet has enough torque. also, it would be great if it can handle lipo reciever packs directly!!!
Thx...
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-13-2008, 06:28 AM   #2
PTP Racing's Avatar
If its blazing speed and lipo compatibility your looking for try and AE or Ace 1015. Its .10 200oz at 6.0v and can handle a lipo. It was like a servo on steriods when using a lipo pack unregulated.
I had to switch it out for something slower because it felt twitchy to me it was so fast. Now I am using Hitec 5955 servos. They arent as fast and that makes it easier for me to handle while using an unregulated lipo.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 10-13-2008, 06:48 AM   #3
tex1's Avatar
Send a message via Yahoo to tex1
Red face The MBX-6 has a ton of steering!
Teeforb,
I implore you to run a regulator if you can. With LiPo the little light on the regulator may not be much but it will indicate your voltage is reaching a concerning level. Your servos will still get increased voltage as compaired to running NiMh packs. My much More and VXR regs put out a consistant 6.3V. The nice thing is it does this all the way through the packs charge. This keeps you driving the same through a long main. Your servos will thank you as well.
Without the regulator it will be harder on the servos when you hit something. They will be allowed to pull more amperage and more prone to burning up. As the battery's charge fades your servos will noticeably slow down. No matter how good you are, your car will feel different.
I like the Futaba BLS9451 for steering and throttle duties in my buggys. They seem durable and being brushless, I figure we shouldn't see fade in performance from motor degradation. I have heard good things about the Ace servos as well as the HiTechs.
My .02.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 10-13-2008, 08:29 AM   #4
teeforb's Avatar
can u send link to regulators? Also, when ever i get the MMM ESC, can i use the BEC on that with a separate receiver pack? OR, is the BEC on that ESC can only be used with the main battery pack?
Old 10-13-2008, 11:50 AM   #5
you should really run a regulator witha lipo pack as described above. you gotta monitor the voltage on a lipo so u dont discharge it to much.
the regulator i run is this one http://www.amainhobbies.com/product_...ducts_id/13509
some ppl also run a losi one
EDIT:
o and for server im running the new hitec 7955 in my buggy or the hitec 5955 is good to
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 10-13-2008, 12:09 PM   #6
teeforb's Avatar
Thx guys, i think i will use a regulator....
I have a ACE 1015, but that is saved for my Truggy when ever i get a new one.
Old 10-13-2008, 12:13 PM   #7
teeforb's Avatar
One question for you guys that I do not think was answered. Using a CastleCreation MMM, can I use the BEC on that with a separate lipo receiver pack or is that BEC only for the main 4s/5s lipo battery that will be used to power the motor? Note this will be an E-MBX6.
Thx!!!
Old 10-13-2008, 12:22 PM   #8
desertbird's Avatar
You're in the "Nitro Off-Road" section asking about BEC....?
desertbird is offline   Reply With Quote
Old 10-13-2008, 12:28 PM   #9
lol ya i have no clue wat a BEC and all that stuff is...wrong section lol
Old 10-13-2008, 12:33 PM   #10
teeforb's Avatar
yes, my bad... pls disrequard that question.
Old 10-13-2008, 12:37 PM   #11
Those new Futaba brushless servos. BLS351.
http://www.amainhobbies.com/product_...ducts_id/23757
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 10-13-2008, 12:43 PM   #12
teeforb's Avatar
has anyone ever used the airtronics 94360 servos?
Old 10-13-2008, 12:55 PM   #13
desertbird's Avatar
I am not familiar with the particular ESC, but if the speed control has BEC it will power Rx and Sx with out the need for a regulator if the BEC circuit is rated for 4.8 or 6 volts. WIth the high end digitals you will want a 6 volt BEC. any thing less and the BEC should be bipassed a regulator installed off your 4s to your Rx. This usually means cutting off the red wire on your throttle and feeding the power from the regulator. It's been a while and someone might have to correct me, but that's what I remember from heli's.
Old 10-13-2008, 01:18 PM   #14
desertbird's Avatar
I meant to add and forgot. If your paying $100 or more for a servo and like the speed and torque specs your looking at the correct servoe
Old 10-13-2008, 01:27 PM   #15
teeforb's Avatar
Well, I have the 94360 servos. They are blazing fast, but not sure if it has enough torque for buggy. It's recommend for 1/10th throttle and steering and 1/8th throttle only. So, i wanted to see what are people using for 1/8th scale buggies.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Big Lot of R/C gear for sale !!! blackdog R/C Items: For Sale/Trade 13 07-09-2008 02:52 PM
Mini LST v. Mini T v. RC18T SUNA Micro and Mini Scales 32 02-18-2007 09:30 PM
