Old 10-12-2008, 09:45 AM   #1
Default Engine not running rich enough----need some help here
hey guys, i need some help here for some reason, the AE .15 on my RC10GT won't run rich enough. i noticed not enough smoke coming out, so i reset to factory needle setting for high speed put screw all the way in, and brought out 2 1/2 turns, and now it's even worse i've backed it out A LOT and it still won't run rich
any ideas?
Ma-Deuce is offline   Reply With Quote
Old 10-12-2008, 09:59 AM   #2
Integra's Avatar
any ideas?
imo stock needle setting's can only get u soo far.....id back the highspeed out till its blatently Rich....then tune it with the highspeed till its got decent top end and running consistent...then worry about the bottom end.
Old 10-12-2008, 10:05 AM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
If you have backed the needle way out and it still runs lean then there are two main things to check. First would be a blockage. Take the fuel line off at the carb and the pressure line off at the pipe and blow into the pressure line. Fuel should come out the line VERY easily with little effort. Next would be an airleak of some sort, most likely in the tank. GT tanks can crack and leak air, lines can have holes in them, HSN banjo fitting could be loose, etc.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-13-2008, 03:15 PM   #4
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
you might also check that the brass sleeve that holds the HSN isn't loose where it screws into the carb. We had that happen on a .26 once, and the entire sleeve was turning with the needle, increasing the size of the air leak (leaner) with every left turn.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Need HELP with V-Spec Mo-Bo0st Nitro Off-Road 9 07-12-2008 08:47 AM
How To Break In ?????? MaTt 93 Nitro Off-Road 11 10-09-2007 01:44 PM
Engine Tuning for Dummies spenzalii Onroad Nitro Engine Zone 4 06-17-2005 07:25 PM
