Old 10-11-2008, 07:31 PM   #1
Default Need help w/ RC10GT (Engine not getting gas)
Hello guys, today I was going to go bashing with my newly bought RC10GT, but for some reason fuel is not getting to the engine. I know the problem, but I'm not sure how to solve it. After I put fuel in the tank, I can see that it is not making it's way to the engine through the connected fuel line, it's only going about 1/2 way through. I looked in the manual, and it says to open and close the fuel lid twice, I did this, but it still did not help. Any ideas on how to solve this?
Ma-Deuce is offline   Reply With Quote
Old 10-11-2008, 07:48 PM   #2
Trader Rating: 27 (100%+)
I'm assuming you are pullstarting the truck?..
With the switch turned off open the throttle servo with your hand so the carburator is wide open. With the electric off it will stay there. Then kink the pressure line over with your thumb. Now you can flip the lid open and closed. It will take more than twice. Watch until the fuel gets to the carb, then give it another flip open/close. Now it will be primed.
Easier way to prime.. Switch still off, open throttle servo with your hand. Now put your finger over the hole in the muffler (stinger). Give the pullstart three or four tugs. It should now be primed.
Did you buy this new or used?
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 10-11-2008, 07:54 PM   #3
new...I have experience with on-road though, and have actually never had this problem.
EDIT: yeah, pullstart =D
Old 10-11-2008, 08:21 PM   #4
If it won't prime after all that I'd take it back to the hobby shop and let them give it a go.
You can try taking the fuel line off the tank, open the carb, and blow thru the fuel line. If you can't blow thru it then you need to take the high speed needle assembly apart and clean anything up in there.
Good luck.
Old 10-12-2008, 11:33 PM   #5
David Day's Avatar
Send a message via AIM to David Day Send a message via MSN to David Day Send a message via Yahoo to David Day
I had this problem when I bought my GT brand new.. Took it to the hobby shop, and come to find out the carb assembly wasn't together properly. Definately check the carb out first
Day Brothers Racing
*http://daybrosracing.webege.com*
2nd Place 2006 Winter Series 10th/Scale Gas @ Lake Havasu RC Raceway
RC10GT - Snoopy #5x
Kyosho Inferno777 WC SP2
David Day is offline   Reply With Quote
Seberang Jaya RC Track xrays Malaysian R/C Racers 5472 11-19-2016 10:15 PM
B.R.C.C.C (Tingalpa) hooked_on Australian Racing 6962 11-07-2011 01:58 AM
Greater L.A. R/C Racing Club Has Some Good News!! gwilli2001us Racing Forum 787 07-09-2009 12:23 PM
R.O.A.R. Region 12 Gas Championships gwilli2001us Nitro On-Road 80 10-23-2008 05:07 PM
How To Break In ?????? MaTt 93 Nitro Off-Road 11 10-09-2007 01:44 PM
