Old 10-10-2008, 05:07 AM   #1
doctordrew's Avatar
Default MBX6 SETUP
So i love the car and drove it for the first time last night
this i my 6th mugen so im no stranger to the brand.
but i am lookng for some set up .for a smooth med bite clay track.
going to change some things tonight that i did not like yesterday on the track.just looking to start a set up thread if there hasnt been one yet
www.glenwoodrc.com
doctordrew is offline   Reply With Quote
Old 10-10-2008, 06:00 AM   #2
Trader Rating: 163 (100%+)
the base set up sheet is good from the kit, just drop the shock oils down to 400 front and 350 rear, which equals 35 front and 30 rear in wt measurements, the diffs work well with 552
cjm1126 is offline   Reply With Quote
Old 10-10-2008, 07:39 AM   #3
CanyonCarverR1's Avatar
Can you describe the handling characteristics that you didn't like?
CanyonCarverR1 is offline   Reply With Quote
Old 10-10-2008, 07:57 AM   #4
doctordrew's Avatar
well at first i thought that the car was to (springy??)
meaning it was bouncing allover the place.
consequently my first thought was to make the shock oil heavier. but after finding the other thread. I feel i may have been mistaken and need to go the other way!.
also i didn't give much thought to center diff oil as they give you 7000 in the kit so same o same o i put it in now realizing that i should lighten it .
the car was lose at first chasing it all over the track . but this was poor tire choice so i changed tires and then it wouldn't turn at all on power
so i am going to run 5/5/2 instead of the traditional 5/7/1/
www.glenwoodrc.com
Old 10-10-2008, 08:00 AM   #5
Hmm, with that "springy" feel I would also think of going with thicker oil. I'm interested to know what you learn, keep us posted please.
Old 10-10-2008, 08:22 AM   #6
doctordrew's Avatar
i will not be able to run it again untill sat morn. so i will let you know what i come up with by the end of the weekend
www.glenwoodrc.com
Old 10-10-2008, 09:17 AM   #7
Mugen9112's Avatar
Send a message via AIM to Mugen9112
I will post scott hughes official worlds setup sheet once I get off work. It seems like a really good setup but then again I haven't run my mbx6 yet...
Also it seems like a lot of people are going with 5 in the center. How does the car like this setup?
Mugen MBX6-T
Team Associated B4
Team Associated B44
Mugen9112 is offline   Reply With Quote
Old 10-10-2008, 09:49 AM   #8
doctordrew's Avatar
i am going to try 5 in the center sat. at the races. i had 7 in it and i think it was to much for the tight corners on my track.
I ran 4/4/2 in my d8 and to my surprise i liked it so i will change the 6 tonight
www.glenwoodrc.com
Old 10-10-2008, 10:07 AM   #9
jpz_67's Avatar
Trader Rating: 56 (100%+)
I am running 5-5-2 in the diffs , 450 oil front and rear in my shocks, 2.75 rear toe and 2 degrees antisquat and my car is already pretty close to where I want it. The car has really good traction and very stable. Only thing I am still tuning on is the feel of the steering . The car turns in really hard but the mid to exit has more push than I would like. But other than that the car is awesome.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 10-10-2008, 10:26 AM   #10
doctordrew's Avatar
+1 i agree with the above
www.glenwoodrc.com
Old 10-13-2008, 09:37 AM   #11
doctordrew's Avatar
so i changed the diff fluid to 5/5/2 and it cornered a lot better
then i changer my shock oil to 400 in front and 300 in rear(didn't have any 350) and the car was a lot more settled. not bouncing around so much.
the other thing i found is the rear sway bar was to tight. with the new holders it is easy to tighten them down so they wont move. so i would suggest to check this on your assembly.
the only thing that i need to work on yet is exit corner speed. the car was either way lose and doing doughnuts or wouldn't turn on power at all. need to try to find a happy medium.
will post when i get it figure it out.
www.glenwoodrc.com
Old 10-13-2008, 10:44 AM   #12
RBMike's Avatar
I ran my with a similar set-up only I had 7K in the center diff & 1 deg of rear antisquat. Our track is loamy & normally ran damp. The car work great but would become a little tail loose as the track became more dry. Still thinking about what changes to make. Over all I'm very happy with cars handling.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 10-13-2008, 12:57 PM   #13
Mugen9112's Avatar
Here's Scott Hughes setup sheet from the worlds
Mugen MBX6-T
Team Associated B4
Team Associated B44
Old 10-14-2008, 11:49 AM   #14
doctordrew's Avatar
thanks for the set up!!!1
not much different than mine other than anti squat and droop. i will have to play with those tonight.
any opinions on how the worlds track was as far as rough or smooth ,tight or lose????
www.glenwoodrc.com
Old 10-14-2008, 03:57 PM   #15
Mugen9112's Avatar
I think some parts were rougher than others but all in all the track was a medium of the two. Either way Scott's setup is not only a good setup but also a good starting point if your track is completely different
Mugen MBX6-T
Team Associated B4
Team Associated B44
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
rank the top five buggies dreaux Nitro Off-Road 143 08-08-2009 09:09 AM
Mbx6 or Hotbodies D8 halfman Nitro Off-Road 46 04-03-2009 11:19 AM
Electric 1/8 Rules Debate Jube Electric Off-Road 234 02-26-2009 06:48 PM
