Old 10-08-2008, 03:37 AM   #1
Default Direction of Fuel outlet Nipple effecting flow rate?
Hi all
Just wondering if you have to line up the fuel outlet nipple so that the whole in the brass HSN flows directly into the outlet whole in the little round bulp that that fuel line connects onto.
or is it possible to just point the nipple in the direct that would work best for fuel line routing and then just tighten the HSN brass body up. Would the fuel just fill up the bulp then go out the outlet and would this be enough flow?
If i had full flow having all the wholes lined up then changed it so the wholes did not line up would it effect my tune because of a possible flow rate change?
I am trying hard to make sense
thanks!
MBX5R - OS VSpec - Futaba 3PKs - Hitec 5955's- LRP Lipo - Proline
MBX5T - RB C6 L2G - Futaba 3PKs - Hitec 7955's - LRP Lipo - Proline
pracy is offline   Reply With Quote
Old 10-08-2008, 11:56 AM   #2
Trader Rating: 27 (100%+)
You can rotate the fuel nipple in any direction without hurting anything. So just loosen it up, turn where you want it, and snug it back up. Don't overtighten though, especially on engines that the nipple (banjo fitting) is plastic.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 10-08-2008, 03:35 PM   #3
Allumina's Avatar
Send a message via AIM to Allumina
The beauty of a banjo fitting is they will work when turned in any direction, like the guy above me said though, be very careful not to overtighten it once you've adjusted it where you like, the brass threads can very easily snap off in the carb and then you got a real problem!
[COLOR="Red"]Kyosho[/COLOR] - MP9 & ST-RR
A[COLOR="red"]K[/COLOR]A - Tires and Wheels[COLOR="DarkOrchid"]Novarossi Racing Engines[/COLOR] - 21-4 Plus & Toro Nero
Houstons Engine Service - [email]houstonsengineservice@live.com[/email]
Allumina is offline   Reply With Quote
Old 10-11-2008, 06:02 PM   #4
thats good so the nipple can face in any direction. that makes the fuel line routing easier. i nknew it was a banjo fitting and how they work but was worried about effecting fuel flow and or fuel pressure...
cheers
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
Aarcmcc Rules TrustMe Australian Racing 43 10-10-2005 01:15 AM
Engine Problems LosiSuperTruck Monster Trucks 4 10-07-2005 05:40 AM
