Changing wheel on Ofna's crome top starter box?
Ok this makes me feel like such a noob, but I need to change out the starter wheel on my Crome top starter box from ofna, the wheel is the bell shaped one that comes taped to the bell type metal piece. I cant seem to figure out how the old bell comes off? I removed the screw, But its still stuck on there so tight I cant budge it! Anyone have a clue????
just take a little hammer and pound it a little bit it will come off.. the whole metal [piece will come off the shaft
I tried that! i 'll be damned if this wheel is not like welded on, I am at the point where I need to dremel the metal bell a bit on both sides of the shaft to loosen it up a tad. This freakin thing is stuck like a weld! I was wacking it with the hammer, from every possible direction and its not budging! I even measured the damn shaft with my calipers to see if the bell is moving forward at all! Nothing! It's dremel time!
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
I just built one... I remember the diagram was... odd. Here's the bottom line:
You need a wire from the battery to the "lid switch" and that wire should also connect to the red charge jack. That wire is a long red wire and has 3 connectors- the "half ring" goes to the "lid switch," the long end goes to the battery, and the short end goes to the red charge jack.
You need a wire from the other post of the lid switch to the on-off switch. That one is just a short red wire. One end is a "half ring" (to the lid switch)
The red wire on the motor goes to the other side of the on-off switch.
The black wires connect the motor, the battery, and the black charge terminal.
Hope that helps. The diagram kinda sucks that comes with it.
