Old 10-01-2008, 10:06 PM   #1
offr0aden's Avatar
Default The JP-3 pipe question
I've been searching for the answers and thought I would get some views and opinions from you racers. I have a JP-3 pipe on the OS VZ-B V-Spec and it runs well. I was cleaning it up after a race and took a look down the inlet of the pipe and found that mine has no chambers. Is that right? I've never owned a JP pipe this being my first, I'm not sure how it's claim to be a 3 chamber.
Can someone explain?
offr0aden is offline   Reply With Quote
Old 10-02-2008, 09:51 AM   #2
Trader Rating: 27 (100%+)
Poke around in there with a coat hanger and see if you hit anything..
If it didn't have the parts it's supposed to you would hear a difference between it and any other jp3.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 10-02-2008, 10:00 AM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
Three chamber refers to the three different sizes of the pipe, if you notice it is tapered from the header to the stinger, that is what they mean by 3 chamber, the inside of the pipe is empty. I thought it was very strange also, since it has no interior baffle system, but that is the way its made, and nothing wrong with your pipe.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 10-02-2008, 12:11 PM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
Uhm, not quite. A three chamber pipe is three chambers.
Chamber 1. The divergent and convergent cones. This would be the expanding cone the exhaust first enters and then into the convergent cone (often has little oil drain holes drilled into it, shine a flashlight down in there and you can see it).
Chamber 2. This is basically a can shaped cap that goes over the end of the pipe. The hole in the middle of the convergent cone empties into it. There is a hole in the side of this cap where the stinger is attached to form the outlet. In a two chamber pipe this would be it.
Chamber 3. This is basically just a big washer that is welded over the end of the convergent cone and inside the end cap. It blocks all the exhaust gas (and sound) from even getting to the stinger except it has a small flat spot on one side to let the gas escape and as such forms a third chamber within the pipe. You will not see it without cutting open the pipe.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-02-2008, 12:24 PM   #5
Jaz240's Avatar
Ok well said, lol proving I have no clue what I'm talking about, however the fact remains that these pipes have nothing inside them, so if they are being described as 3 chambers, that's a flat out lie, because they are hollow inside, so it should read no chamber pipe, I was using reasonable deductions, and apparently I was way off base. thanks for the lesson! Jaz
Old 10-02-2008, 12:54 PM   #6
wingracer's Avatar
If there really is nothing inside of it it would be a 1 chamber pipe. If you have ever seen the pipe the AE RC10GT came with (and some other 1/10th AE stuff) that is a 1 chamber pipe. I haven't seen a JP-3 up close so I don't know what it is. I will take a look at a JP-1 I have when I get home.
Team Shepherd USA
Old 10-02-2008, 04:12 PM   #7
wingracer's Avatar
Ok, I just looked at a JP-1 and it is definitely at least a two chamber. I can't tell if the washer looking baffle is in there or not to make it a three chamber. I'd have to slice it open to tell.
Team Shepherd USA
Old 10-02-2008, 04:26 PM   #8
wingracer's Avatar
Go here and scroll down a bit for diagrams of pipes.
http://www.efra.ws/pdf/handb08_homologation.pdf
As you can see from the drawings, if you look into the pipe all you will see is the end where the mount is. That end is chamber 2. Chamber three is after that and invisible.
Team Shepherd USA
Old 10-02-2008, 04:47 PM   #9
Davidka's Avatar
Trader Rating: 75 (100%+)
JP 1 and 2 are two chamber pipes, the 3 is a 3 chamber.
JAzz, shine a light inside the pipe from the header end. You will see that while it appears to be hollow and shaped like the outside shape of the pipe the inner wall is missing the hole for the stinger as well as having a hole in the center at the end.
Started to only allow 3 chamber pipes the season of the 2006 worlds, right about the same time as the JP-3 and OS 2060 pipes came to market (both 3 chambers).
Old 10-02-2008, 06:52 PM   #10
Jaz240's Avatar
i got ya, and I looked, and did see what you are refering to. I was expecting to see some sort of baffle in there, and not be able to see the entire interior of the pipe, for my thought process is, where are these cambers? But your explaination makes perfect sense. I never really paid attention, nor cared how many chambers a pipe has, I just know that's the best pipe for my V-spec, and my track, Thanks for the heads up from all of you, and for setting me straight.
Old 10-02-2008, 07:19 PM   #11
Davidka's Avatar
Yep, there's really less to them then what you'd expect.
I don't understand the reasoning behind requiring 3 chambers. The two I have experience with are just as loud as anything else except a JP1, that thing is like an amplifier!
Old 10-02-2008, 08:43 PM   #12
offr0aden's Avatar
Thanks all - it just seemed odd when looking down. I'll take a closer look before I mount it.
Old 10-03-2008, 09:44 AM   #13
joeling's Avatar
Is this pipe a suitable match for the OS speed on a smallish technical track with many jumps ? Can't seem to find the 2050 anywhere. Thanks.
Regards,
Joe Ling
HN X2 CR OS Speed WC Ti, HN X1 CR Polyquest 5S Neu 1512 2000kv MMM
HN X2 Neu 1515 2000KV Polyquest 5S 6000mah MMM, HN X2 OS Speed WC
Hyper 9e Medusa 2000KV 4S 6000mah MMM, Hyper mini STe Medusa 3300KV 3S 2500mah MM
Savage FLM ext. 5S MMM 8XL, E REVO Medusa 1600KV 6S MMM
Thunder Tiger ST Neu 1515 2000KV Lutach esc 5S 4800mah
joeling is offline   Reply With Quote
Old 10-03-2008, 05:40 PM   #14
Davidka's Avatar
Regards,
Joe Ling
Yes, it should be GREAT for that type of track.
Old 10-04-2008, 06:26 AM   #15
joeling's Avatar
Hi Davidka,
Thanks for the info. Here's some pics of the track I run at :
Regards,
Joe Ling
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
JP-6 JP-1 QUESTION NEMESIS44 Nitro Off-Road 13 11-06-2008 11:09 AM
Losi 8ight-T Race Roller engine type paco62 Nitro Off-Road 22 03-03-2008 07:47 PM
Quick question about 1/8 scale buggy engine. Swede#1 Electric Off-Road 16 07-26-2006 11:07 PM
