Old 06-09-2009, 02:37 PM   #526
Tickle's Avatar
Trader Rating: 32 (100%+)
Unhappy Nose down...
Originally Posted by buggydad View Post
Hello adam I'm having a little issue with my losi 8ight 2.0 diving over jumps.When i throttle over the jumps its fine but i then over jump the down side.What would you recommend as far as tunning?
And do you ever make your way to the east coast. If so stop by Hobbyhut LOL for a club race http://www.youtube.com/watch?v=aaZlcM09Ktg
I know the jump your talking about. The double right in front of the drivers stand. There is a left hair pin turn right after it.
My Losi 2.0 8ight T does the same thing. I have to pin the trottle to keep the nose up. I've over jumped it so bad I ended up in turn one.
One thing that helped me was to stay on the left side of the track. There seems to be less lip on top of the jump on that side. It also helps if I approach the jump slower, but launch harder off the top.
I'm listening to see if Adam has any suggestions because it only happens to me on that jump.
Back in the TC race!
Horsham RC!
Trains and Lanes in Easton, PA
Tickle is offline   Reply With Quote
Old 06-09-2009, 04:19 PM   #527
Integra's Avatar
comment's like that are not needed...thank you.
Old 06-10-2009, 03:53 AM   #528
buggydad's Avatar
Originally Posted by Adam Drake View Post
T4-RC8 RACER77: http://www.losi.com/RaceCenter/Disco....aspx#LOSK0800
aaron_buran: Make sure you clutch and clutch bell bearings are in good shape. Also try running a hotter glow plug. I usually start with full rebound in the front and 3/4 rebound in the rear. If the track is low grip or bumpy, the more rebound the better. I only take rebound out if the track is very high grip. With your barkes you need to make sure the screws the hold the top of the center diff mount aren't too tight. You may also be running too much play between the brake disc and the brake plates.
axial28rr- I race for Nova Rossi.
dcracing- Gad the set-up worked well for you. Please feel free to ask any questions you have about the 8ight or the 8ight 2.0 if you get one. You can run the 2.0 center rear drive shaft on the 8ight and it will solve the problem.
buggydad- The track looks cool. Is the buggy jumping nose up or nose down? Try this set-up: http://www.losi.com/ProdInfo/Files/ADSilvStA0804.pdf
Pete Martinez- It's possible, just depends on my schedule. I would like to attend Motorama one day.
I switched to that setup minus the shock piston drilling.I think i have found the issue tho the rear shock preload was set to low.I raised the rear ride hieght and it does it half as much now.I think my rear chassis was slapping the lip.I'm going tonight to practice so ill see how everything works
buggydad is offline   Reply With Quote
Old 06-10-2009, 07:49 AM   #529
hey adam i have the 8igh starter box and it works fine but now that i have the 2.0 buggy and truggy it seems a little diffent seeing how the truggy is longter then the 1.0. it still starts it fine but was wondering what box/boxes you ues thanks
Ray's Hobbies
8ight 2.0/Novarossi Plus-4
8ight 2.0T/Novarossi Plus-4
HAWK498 is offline   Reply With Quote
Old 06-10-2009, 08:10 AM   #530
Integra's Avatar
the foot print of the 2.0's is no bigger then the 1.0's...which is how they kept the box stock and it still works...1 thing to make sure of is that the wheel is not touching the chassis when it's not supposed to....I suggest pulling your motor and lining up the box with the chassis to make sure its 100%...if the wheel so much as touches the chassis it can lead to problem's.....i know for a fact adam and the losi boys use the losi box.
Old 06-10-2009, 08:30 AM   #531
Xchange's Avatar
Trader Rating: 10 (92%+)
Hi guys,
I m currently running one Hot Bodies D8 Lightweight but i m borred with it.
Now, i m seeing to buy a Losi 8 2.0 Race roller but i see a lot of 8 on my local track and they broke easy.
Any one having this issue?
The car is easy to tune ?
Is durable ? or you need to invest 500$ in hop up ?
Thanks guys
Xchange is offline   Reply With Quote
Old 06-10-2009, 09:03 AM   #532
warpig's Avatar
I'd like to know how they are breaking them. They are very durable.
warpig is offline   Reply With Quote
Old 06-10-2009, 09:11 AM   #533
ive been racing the 8 for two years and i dont think i have broken anything on it since as far as the car itself
Ray's Hobbies
Old 06-10-2009, 09:16 AM   #534
Xchange's Avatar
thanks,but why a lot of guy striping the servo saver?
and do you have problem with the bearing?
Old 06-17-2009, 06:36 PM   #535
buggydad's Avatar
I got my buggy setup now just needs a little more playingthanks
Adam did you get to try the rear chassis brace shock?How do you like it?and does it make for a wider range of tuneing?THANKS
Old 06-18-2009, 08:41 AM   #536
I recently traded for a Losi 8ight buggy. The clutch was worn out out so I asked for help on what to order. I was told to order an aluminum clutch kit with gold and green springs. Now in this post it looks like some of you are running 2 aluminum and 2 plastic clutch shoes and the same springs. what is the benefeit of the 2 different clutch shoes and springs? More smooth power delivery? thanks for any help you can give
Revo 3.3
Losi 8ight
Stampedes xl5
rage326 is offline   Reply With Quote
Old 06-18-2009, 08:53 AM   #537
reggie l.'s Avatar
T4-RC8 RACER77:
YES ADAM YOU NEED TO COME!!! bring the lst and shut mike battalie down!!! its a big mt turn out, just run it for old times sake
kould we see drake for
truggy
buggy
mt
nxt '10 motorama!?!?!?!?!?
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 06-18-2009, 09:41 AM   #538
I have had the 8 since it came out and on both the truggy and buggy I have broke one spindle - clutch bearings i just change ofter,, thats it
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-18-2009, 01:03 PM   #539
losi_racer's Avatar
Trader Rating: 25 (100%+)
i have both 2.0s and they both fit fine, the 8t 2.0 i do have to push it all the way back,there is a little bit of play
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-18-2009, 02:33 PM   #540
Integra's Avatar
and......
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
