Old 04-23-2009, 06:53 AM   #496
I ordered a Losi 8ight 2.0 race roller, Jr z9100 s&t servos, nova bf .21 limited edition / dynamite 086 pipe, receiver pack, ofna truggy box and battery, spare filters, glow plugs, yesterday with amain. I had the rtr version on back order but they pushed the date to may 25th and I couldnt wait any longer so I went with the roller instead. Im sure I will be better off anyway. I need some tips on my assembly process and break in procedures.
roadracer43 is offline   Reply With Quote
Old 04-23-2009, 08:11 AM   #497
Akhor's Avatar
The race roller comes pre-assembled. However I would rebuild the diffs and shocks to make sure that they are up to your standards.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 04-24-2009, 11:38 AM   #498
dcracing's Avatar
How would going from 2000 to 3000 in the rear diff affect handling? I'm running 5-5-2 now.
BCE Mugen Mbx6
Novarossi
Byrons
dcracing is offline   Reply With Quote
Old 04-26-2009, 05:20 PM   #499
dcracing's Avatar
Originally Posted by dcracing View Post
Hello, I am still running the old Losi kit buggy when I prep it for a race its suspension is moving free. After a few minutes on a track it gets a little stiff and squeaks in the front and rear arms and steering linkages. Is there anything I can do to keep this from happening? Does this happen to anyone else? Also, I have been working on a setup for my local tracks. I got the buggy turning very well and it rotates nice while staying easy for me to drive. My only problem is it seems twitchy on-power and will spin out if im not careful. I think I need to move the front camber links from the "3" to the "2" position, making them longer. I figured I would ask you guys 1st. Thanks.
Nevermind... I put 3000wt in the rear diff and its alot better. As far as the squeaking goes I tore down and rebuild the buggy cleaning it and it still does it.
No biggie.
BCE Mugen Mbx6
Novarossi
Byrons
Old 04-26-2009, 05:22 PM   #500
dcracing's Avatar
I tried it today, Less aggressive turn in and lost a little steering in the center and exit which is what i needed.
BCE Mugen Mbx6
Novarossi
Byrons
Old 05-20-2009, 11:52 AM   #501
Adam Drake's Avatar
Integra- It's not a concern. When you have the shock boot and cup on the shaft the piston won't go up to far.
dcracing- If the steering and camber link ends are binding up you can pinch the ends a little with pliers and they will free up.
losi_racer- I would check the tank and fuel line.
Adam Drake is offline   Reply With Quote
Old 05-20-2009, 12:04 PM   #502
Integra's Avatar
thx for the clarification Adam.
Old 05-21-2009, 06:32 PM   #503
Guest
Send a message via Yahoo to T4-RC8 RACER77
Default Setup
Drake I am looking for some of the older setups for the older buggy. It is I of the first setups for the buggy? Please help ??
T4-RC8 RACER77 is offline   Reply With Quote
Old 05-21-2009, 09:17 PM   #504
Trader Rating: 30 (100%+)
i think the setups are still on losi web site if not here is what i remeber
1.0 set up
diffs 5-7-2
front shocks 54 piston on 40wt oil
rear shocks 55 pistons 32.5 oil or 56 on 30 oil
3 deg x 3 toe back plate
hubs all the way back in rear
inner on tower in front
inner lower on tower in rear and inner on rear hubs
droop 95mm front 106mm back
ride hieght 27mm front 29mm rear
bump steers down
long ackerman arm
-2 camber front and -1.5 camber back
jewn_beef is offline   Reply With Quote
Old 05-22-2009, 01:01 AM   #505
Guest
Default Setup
I seen those, I am looking for one of the first setups that was post for the first buggy when it came out. The guy that had it, had a weird last name started with a E?? The setup call for the other springs in the kit to be used
Old 05-26-2009, 06:11 AM   #506
aaron_buran's Avatar
Hi Adam, I have a couple questions for you:
1.) This past weekend I had a re-occuring problem, if I overshot the landing on a jump and landed hard the car would flame out. I checked the clutch springs, the tightened the tank lid, played with the idle and needle settings (even though the engine seemed to be running fine), I went over the entire fuel system etc.... Any ideas? The only thing that I noticied is that my chassis has alot of wear on it, and my spur gear is flush with the bottom of the car, the surface was very uneven and hard, might the spur have been bottoming out on the track surface with clutch engaged?
2.) My car wasn't jumping well and nosing over alot, Kevin Wilson suggested that I rebuild my shocks with full rebound. It improved my car dramatically over the jumps, how much rebound do you build into your shocks? Is it track depended, if so what do you look for in terms how you build your shocks for a given surface.
3.) I have spent alot of time trying to get my brakes to work consistently, at times they are good, and at times they are not. I also have noticed that at times the front disc actually binds up and sticks when testing the settings on the ground. What are the top things to do to maintain and set them for consistent operation?
Thx,
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 05-27-2009, 06:42 PM   #507
Default Grp plant buring down
hey Adam what do you think about this man are you goin to start running losi engins or find a new sponcer ship
Modified Team Losi Aftershock
Axial28rr
Race ready
axial28rr is offline   Reply With Quote
Old 05-27-2009, 06:50 PM   #508
dcracing's Avatar
Drake is running Novarossi for a while now. GRP is great, my Ninja BO1a is on its 9th gallon and still running strong. Hate to see them go down like this...
BCE Mugen Mbx6
Novarossi
Byrons
Old 05-27-2009, 07:01 PM   #509
dcracing's Avatar
Adam, I tried Mike Truhe's 2007 Nitro Challenge set-up w/ the TFT chassis, drilled 54 pistons in front, and bow-fighters. It is an amazing difference in how the buggy handles now. Other than how you build shocks, do you have any other tips for the 8ight competition kit. All your replies on this forum have been very helpful to me, even though I don't run the 2.0
BCE Mugen Mbx6
Novarossi
Byrons
Old 05-27-2009, 07:10 PM   #510
buggydad's Avatar
Hello adam I'm having a little issue with my losi 8ight 2.0 diving over jumps.When i throttle over the jumps its fine but i then over jump the down side.What would you recommend as far as tunning?
And do you ever make your way to the east coast. If so stop by Hobbyhut LOL for a club race http://www.youtube.com/watch?v=aaZlcM09Ktg
buggydad is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
